Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-01-2009, 11:41 PM   #1
TXredc3
CF Senior Member
TXredc3's Avatar
Default How Do I Get Paint To Shine?
I had my '74 repainted 3 years ago with a base coat/clear coat. I thought it was a nice job and was even complimented on it by a guy that paints cars part-time. The car's been in the garage 99.9% of the time. Fast forward 3 years. Now the paint's not smooth like it used to be and it has a dull look to it. I hit it with several different products. I tried Meguiars paint cleaner, Polish, and then a wax. I even tried a turtle wax brand of rubbing compound. Nothing did much good. Any suggestions?
TXredc3 is offline   Reply With Quote
Old 04-02-2009, 12:00 AM   #2
hwcoop
CF Senior Member
hwcoop's Avatar
Color sanding/buffing video by Kevin Tetz
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
hwcoop is offline   Reply With Quote
Old 04-02-2009, 08:13 AM   #3
TXredc3
CF Senior Member
TXredc3's Avatar
Can you color sand when you have a clear coat?
Old 04-02-2009, 08:33 AM   #4
groovyjay
CF Senior Member
groovyjay's Avatar
Quote:
Yes.
groovyjay is offline   Reply With Quote
Old 04-02-2009, 09:23 AM   #5
karol
CF Senior Member
karol's Avatar
My suggestion is to go to the forum jump and look at the "car care discussion" and read or post.
Are you applying these products by hand? makes a big difference in the correction of maring, halos, swirls, scratches, etc. Basically you are working on the clear coat. Dont buy anything that says it is for a certain color of paint. You dont dye a clear coat. Glaze is to make it look pretty and fill in the imperfections for awhile, etc,etc. There is really a lot more to detailing then you think possible.
I use a PC 7424 and suggest it might take a machine to get it back the way it was.
good luck.
karol is offline   Reply With Quote
Old 04-02-2009, 09:27 AM   #6
turbojet
CF Senior Member
turbojet's Avatar
Try using a Clay Bar, use a medium bar first also use a quick detailer as you glide it, after wash and use what ever wax you have.
You should see some results.
turbojet is offline   Reply With Quote
Old 04-02-2009, 09:27 AM   #7
Fay vette
CF Senior Member
Fay vette's Avatar
Try a clay bar kit. It brought out good color on my older truck paint. Plan to do the vette here shortly.
Fay vette is offline   Reply With Quote
Old 04-02-2009, 09:46 AM   #8
TXredc3
CF Senior Member
TXredc3's Avatar
Is a clay bar kit basically the same as color sanding?
Old 04-02-2009, 09:58 AM   #9
schmegeggie
CF Senior Member
schmegeggie's Avatar
schmegeggie is offline   Reply With Quote
Old 04-02-2009, 10:04 AM   #10
karol
CF Senior Member
karol's Avatar
This is what clay does. You still need to continue on with the process.
http://www.autopia.org/forum/guide-d...-cleaning.html
Old 04-02-2009, 10:31 AM   #11
schmegeggie
CF Senior Member
Great article. Does she do the clay job?
Oh well...
Old 04-02-2009, 10:34 AM   #12
Curby
CF Senior Member
Cruise-In VII Veteran
St. Jude Donor '06
Support Corvetteforum!
Curby's Avatar
DEFINITELY start with the clay bar, no matter what you are planning to do next.
It is amazing what crap gets embedded in paint while sitting in a garage, where one thinks their car is safe.
The clay bar will remove the impurities that you can not see, and leave the paint like glass. then you can use a medium cut compound adn a wool buffer to get the haze off. Once this is done, and the finish looks good, put on about 3 coats of wax and wax it 2 t o3 times a year, regardless of miles driven.
Be sure to use the clay bar treatment any time the surface is not as slick as glass.
Curby is offline   Reply With Quote
Old 04-02-2009, 10:38 AM   #13
Duke94
CF Senior Member
Duke94's Avatar
I color sanded my 71' and 78' which both had cheap repaints before I bought them. It made a BIG difference in the shine. Hardest part is taking the sandpaper to the paint for the first time. I used 2000 grit wet or dry and the Eastwood "System One" polishing compound. You will be amazed at how good an inexpensive paint job can be made to look. Nothing like a $5K job, but very acceptable.
Gary
Here's a pic of my 78' after color sanding.
Duke94 is offline   Reply With Quote
Old 04-02-2009, 10:59 AM   #14
Theiskell
CF Senior Member
Theiskell's Avatar
Most of the above advice is good. The only thing I would add is that color sanding is not for the novice. Serious damage can be done quickly and from what you are saying I doubt you need to go to that extreme. Post a picture so we have a better idea of what you are working with.
Theiskell is offline   Reply With Quote
Old 04-02-2009, 12:59 PM   #15
Red 71
CF Senior Member
Red 71's Avatar
Location: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
Quote:
If you are not experienced on the technique you can burn through edges real quick. It is also risky unless you know for sure that you have enough clear to allow for sanding.
Red 71 is offline   Reply With Quote
Reload this Page How Do I Get Paint To Shine?
Tags
austin, c3, color, corvette, dull, get, glass, make, paint, sanding, shine, shiner, shne, start, texas, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Because of this Picture, I am goint to buy NXT today.... STRMLNE Car Care Discussion 34 03-24-2004 08:12 PM
How do you keep aluminum valve covers looking shiny? Shrike C3 Tech/Performance 21 11-25-2003 09:37 AM
The paint will shine up real nice.......... Paul G C3 Tech/Performance 14 11-18-2003 05:21 PM
How do you store or display your diecast? DiecastCollector Die Casts & Collectibles 14 01-23-2003 07:58 PM
Considering Zaino - What do I need? vetteman32 Car Care Discussion 13 02-01-2002 11:50 PM
How do I get swirl marks off my car? ShadowZ28 C5 Tech 15 09-10-2001 01:28 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
