How do you paint that part right above the back window
Hi all,
I posted this in paint and body but I know there are lots of painters here too.
I am finally ready to apply the paint to my 74 coupe. Inside doors, jambs, hood ledge, and inside the back window are already painted. the doors are hung, hood is removed and all glass accept front is removed.
All I need to do is final clean up and tape it off which I hope to do in the next week or so.
I have been doing dry runs with the paint gun to try and develop a pattern for the application. However, I can't come up with a good way to paint that little overhang above the back window without the fear of leaning on the car . Then how do you paint the inside of the fins that run down from the back window/I have some theories but they are all cumbersome.
So, ideally I would love to hear the pattern an experienced painter follows on one of these cars. ANY ideas are appreciated.
Thank you
John
Thank you
John
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The money wasted on high tech paint booths!
I loved this video, it’s hilarious! It reminded me of shooting lacquer paint in the 70’s and carrying tweezers and tape for bug and run removal!
I about fell over laughing when he said "All the dirt and sand and bugs and all that and that’s part of it. . . We might just leave them in there!"
Good stuff!
Good stuff!
My first job was a painter's assistant and he never wore anything and painted all his life.
The early St Louis guys never used anything either although they had a nice downdraft booth.
Maybe the paint was different back then. I can't go around paint fumes now without a mask.
Guy looks like he can paint though, however I did worry about overspray on that F-150 hood.
Yeah, priceless.
With the way this guy is spraying in the video I wounder how many runs they had.
30 yrs of painting? I'm no pro at painting but I have sprayed a little. I could be wrong
but I don't think this guy is a professional when it comes to painting.
Just my 2 coins.
Riggs.
Just my 2 coins.
Riggs.
ok first off, he totally leaned on the back bumper when he shot the back roof area. I wonder how he kept from getting a blue jean mark in the second coat.
The lack of safety gear is just amazing and the total disregard for contaminants...
I have a respirator, paint suit, head sock, gloves and goggles. I bought 3 hvlp gravity guns, enclosed the garage in tarps from top to bottom and tied the ends together, spent a whole day cleaning the "paint booth" (garage) and i mean wiping down everything, i cleaned the light fixtures, garage doors and rails, i cleaned the lids on the paint cans! then i mopped the floor twice. i cleaned everything. i feel like such a chump.
so the guy in the video knows he is going to have contamination in every layer and he is cool with it. I am not, but i know it will happen.
So, what can be done to remove stuff like a dog hair from your first layer of clear without without causing too much ancillary work? How do you remove contaminants while you are in the process of painting.
It looks like he's holding the gun really close to the car and using thick coats. I'm no expert but that sounds like a great way to get runs(not to mention the bugs he said he may just leave in there.
paint it from the inside of the car..... you'll get a better angle
i primered my 77 in the driveway... i would have painted it too, but got a good deal for my final paint
I used a small touch up gun and had the rear window out, I painted the overhang first before anything else. I first tried a gravity feed gun and didn`t like the way it was going to work so I went to a small suction cup gun just to do the overhang with. And I was inside the car.
Former Vendor
Paint those areas FIRST from both sides so you can lean against the body if you need to so you can reach that area without worrying about fabric patterns in the side paint. If you're tall then I would think you could reach that area without touching the body panels, but I would still do that area first.
That video is really SOMETHING! It's not an old video judging by the newer-ish truck parked by the door. I've painted a lot of cars, some in booths, some in sheds like that. See a lot of improvement he could do ..but it's obviously a budget job.
1) Should be using a respirator, paint suit, rubber gloves. It's a fact that a good deal of crap in the paint falls off the painter as he/she moves about the car.
2) Would have better results if the car was up on jack stands so ya didn't blow dust off the floor as ya sprayed.
3) Using a decent HVLP spray gun would be better, even a Harbor Freight #4330 would be better and save paint costs.
4) Didn't have the front/rear bumpers separated from the body. This will lead to a 'bridge' of paint at the bumper seam and probably paint will eventually flake off here.
5) Paint technique is really attrocious. He's just waving the spray gun back and fourth ...not letting up on the trigger at end of stroke (that's what leads to runs). His overlap doesn't seem uniform. Better strategy is to do the whole area between the front and rear wheels, to avoit runs at the door seams. But in the end, it matters how well it lays out and maybe it turned out better than it seems.
6) Pickup truck parked right outside the door. Great way to get overspray all over your vehicle!
7) Do ya really need to wear your cell phone?
8) Yeah, the only thing missing was a ciggarette in his mouth!
Check out this Vette painting video: http://www.youtube.com/watch?v=tMDvwhqPTi0
Thanks for sharing!
Mark G
Thanks for sharing!
Mark G
Hi all,
Thank you
John
Thank you
John
BTW: I also used a banadana for my forehead, so as to stop the sweat from dripping on the trunk deck when you lean over...
