69 frame stencil numbers
Old 03-15-2009, 05:46 PM
barbs '69 resto
Account disabled by request 8 Feb 2010
barbs '69 resto's Avatar
Default 69 frame stencil numbers
I have a 69 L46 4 speed coupe, this is a november '68 car. Does anyone know what the frame part number and date information would be? This is the information that is stenciled upside down on the passenger side frame. Thank you for the help.
Old 03-16-2009, 10:33 AM
barbs '69 resto
Default Frame stencil numbers?
I am doing a body off resto on my 69 coupe L46 4speed and would like to find the correct stencil numbers for this car. I can also use any other frame marking info. too. I've surfed the internet for this information with not much success. I'm looking for the numbers and format in hopes to make the stencil myself.
Old 03-16-2009, 01:03 PM
KapsSA
KapsSA's Avatar
From the DocRebuild catalog. 69 std trans frame # 3973880.
I got a couple of stencils from him, had to provide my own dates but for later C3s.
Layout and numbers were accurate except the letters were a little larger than correct.
$14.
Old 03-16-2009, 01:11 PM
bigredbrad
bigredbrad's Avatar
Location: Lincoln NE Riding and Driving Corvettes since 1967.
hey barbs - You should buy the book "Corvette Chassis Restoration Guide" by Joseph Tripoli. There is an UNBELIEVABLE amount of chassis, spring, brake, vin, information, plus tons of photos that will help you. There is even a section that shows you what the letter/numbers should look like. From the Chassis stencil chart, 1969 shows 3973880-xx. The xx is the AO Smith production number and you will need to calculate that. you will also need to calculate your date and that needs to be added also on the second line.
ISBN for the book is 0-9624817-0-x
Good luck with your resto
bigredbrad
Old 03-16-2009, 01:12 PM
bigredbrad
bigredbrad's Avatar
barbs - check the other threadd where you posted the same question. I answered it there. You should get the book.
bigredbrad
Old 03-28-2009, 10:41 AM
barbs '69 resto
Thx Guys
I bought the resto guide yesterday at the vett expo. This information
should help greatly.
Thx again
To 69 frame stencil numbers
Quick Reply: 69 frame stencil numbers
