Hydroboost/Wilwood Combo - AWESOME
Well, yesterday I just completed a major brake conversion. I replaced my vacuum booster with a hydroboost unit, four Wilwood D8 direct fit calipers and Wilwood master cylinder. I can tell you that the Wilwood setup gives you a whole new perspective on bleeding brakes. There are four bleed screws per caliper, one for each piston. After bench bleeding the master cylinder, all you need to do is install it, then the procedure for each wheel - pop open the two bottom bleed screws, wait a few minutes for the fluid to appear, close the two bottom ones, and repeat same for the top ones. It takes about 15 minutes in total for the gravity bleed and you will have an air free system and rock hard pedal. I took the car for a test drive and in one word - AWESOME! The saying 'You can stop on a dime and still have a nickel in change' is an understatement. At 60 mph, I can lock up all 4 wheels with very little pedal effort. This is an amazing enhancement that you will never regret.
Hydroboost Install
Hydroboost Install
Where did you get all the components? This may have to be my next major upgrade. Also, do you have a link to your hydraulic clutch upgrade?
I already have all the parts for the same conversion except one connector. It should be here this weekend. I already had the same Wilwood MC and brakes but have been running an external vacuum pump since my cam just doesn't provide enough vacuum. Now you got me going crazy wanting that part to come in....did you make your own lines? Im gonna give it a try it looks easy enough. Any issues or "I shoulda done this first" notes to pass on?
Note that you can change the orientation of the hydroboost to suit your preference. It doesn't care how it is rotated Bee Jay has his rotated 180 degrees from my orientation. If you have a big block or want some extra room for tall valve pan covers or want to hide hoses, then you may wish to flip it 180 like I have done. If you want easy access to connections, then go with Bee Jay's rotation. Probably other pros and cons to either rotation.
After my frame off is now done and having trouble with even new replacment factory calipers leaking I think Wilwood is the next step for me.
I called a while back to find out about the wilwood d8 setup and they gave me a price of $1400 for calipers and lines.
Did you find a better deal anywhere else?
How hard was it to get to the fittings on the power steering pump?
I know on my BB they are going to be a challenge
Bee Jay
The Wilwood master cylinder is 260-8556P. If you drop the 'p' then you get a unpolished cylinder. It has a 1.12" bore (same a OEM), correct for power brakes. You do not have to change your master cylinder unless you wish. I changed mine because it was the original one that came in the car
Just want to add some comments about these D8 Direct fit calipers:
These are made with the same technology as their racing calipers with
1) Deep Cup stainless pistons to minimize heat transfer.
2) For extreme racing the caliper can be retrofitted with Thermlock insulated pistons just like the race calipers.
Pads are also available from street to full race compounds. Also high temperature brake fluid, either 570 or EXP Fluid could be used.
I did it that way because that is how it sits in my truck. One day when I am really bored, I'll pull out the seat, remove the four nuts, rotate the hydoboost, replace the four nuts, and paint the MC and hydroboost. Maybe I'll go to braided hose too. I'm gonna have to be really bored.
Bee Jay
Bee Jay
Did you need to use special flex hoses or are these new, direct fit just that?
Wilwood brake kit $
The $1,400 quote is Wilwood's MSRP for kits that include the calipers in clear coat with the stainless braided line kits and a set of their BP-10 compound pads. Red or black powder coated calipers, or polished calipers are an upcharge from there. It's generally best to buy through one of the Wilwood dealers.
