How Much Does It REALLY Weigh??
Old 02-20-2009, 07:38 AM
VictoriaVette
VictoriaVette's Avatar
Default How Much Does It REALLY Weigh??
So I know what it say on my dmv reg. but has anyone ever weighed a C3 to seel how much it is? I'm wondering how much mine weighs 77 T Top with AC, Auto. now I have aluminum heads and intake so I would guess a loss of maybe 70-75 lbs?
Old 02-20-2009, 07:47 AM
Gordonm
Gordonm's Avatar
I weighed mine a couple of years ago. It was 3349 with me (150 lbs) in it. So around 3200 pounds. I do have a lot taken out of the car and probably a few pounds lighter now.
Old 02-20-2009, 07:54 AM
VictoriaVette
Tell me about yours year, t top, trans and what you have removed.
Old 02-20-2009, 10:08 AM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Mine weighed 3380lbs w/half tank of fuel at the local drag strip scale. Completely stock/original 71 SB, auto, ac. Only weight reduction was no spare tire and an aluminum intake, headers....
Old 02-20-2009, 11:09 AM
MCMLXI
MCMLXI's Avatar
Finalist 2022 C1 of the Year - Unmodified
2020 C1 of the Year Finalist - Unmodified
C1 of Year Finalist (stock) 2019
Were you in the car when it hit the scale ?
Old 02-20-2009, 11:50 AM
early shark
early shark's Avatar
One of my '71 LS6's I weighed on certified scales. This car is completely stock, with original F 70 15 tires (all 5) with virtually no fuel in the tank and me out of the car, with these options N37, N40, J50, U69/U79, MA6, M22 it weighed 3,340 lbs.
Old 02-20-2009, 11:58 AM
Gordonm
Gordonm's Avatar
Car is a 72 Vert. SB motor alum .heads Full VB dual mount rear transverse front spring setup The rest is in my signature
Old 02-20-2009, 03:46 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
Late '70's C3s are heavier than their chrome bumper siblings. '77 curb weight is going to be more like ~3550#, w/o driver aboard.
TSW
Old 02-20-2009, 03:55 PM
VictoriaVette
The info I found stated 3448 shipping weight. How much less with aluminum heads and intake? 75lbs?
http://www.100megsfree4.com/corvette/1970/vet77.htm
Old 02-20-2009, 04:30 PM
TheSkunkWorks
Shipping weight doesn't include fluids to capacity and 1/2 tank of gas, as does curb weight. BB aluminum heads are ~75# lighter than iron ones, but the savings of alum vs. iron on a SB is likely about half that amount. With alum heads and intake I'd guesstimate you've take off ~50# vs. iron heads and intake. I used to have a chart of all of this, but can't find it.
Old 02-20-2009, 06:45 PM
yel76low
yel76low's Avatar
http://forums.corvetteforum.com/c3-t...3-weigh-2.html
I went to the local dump, weighed 3600 in and 3580 out... so I'm averaging to come up with 3590. Full of gas, me, and some crap in the car.
3590 - 155 (me) - 17*6 (gas) - 26 (tools, etc. weighed them when I got home) = 3307. Take t-tops off and its 3283.
Car is a 76... has AC, spare tire + carrier, and nothing to reduce the weight.
Old 02-20-2009, 06:55 PM
Vampyre
Vampyre's Avatar
TSW
Well.. 1980 to 1982 are the not.
the 1981 Corvette is the lightest C3.
Old 02-20-2009, 09:27 PM
thegavel
thegavel's Avatar
Howdy All,
According to my Rego sticker the weight of
my '74 is 3410 lbs/1550kg (Which is heavier than most
of our Aussie family sedans !!!!!).
Cheers
Gav
Old 02-20-2009, 10:13 PM
mrvette
mrvette's Avatar
I maybe knocked off 20 lbs since then, but my car weighed in at 3300 even some years ago....I was VERY disappointed....
I can understand maybe 50 lbs added from the Muncie to the 200 4r auto, but the engine went aluminum heads, intake, front lights gone, grills replaced, aluminum radiator....electric fans have added weight...but serp drive and small compressor have shaved a ton right there....
I would think I shaved about 150+ lbs off the car weight since I got it....apparently NOT.....
i'ts a convertible....and car shipping weights are in fact totally meaningless....
Old 02-20-2009, 11:33 PM
TheSkunkWorks
However, the OP is asking about a '77; one of the heavier C3's.
Old 02-20-2009, 11:45 PM
VictoriaVette
What makes my 77 a heaver C3?
Old 02-21-2009, 12:53 AM
TheSkunkWorks
Why so heavy? Increasing gov't mandated safety measures for one, after which it took GM a while to put the Vette on a diet. By the end of the C3 run they had found significantly lighter ways of meeting requirements. Plus, I'm not sure the General was paying much attention to performance just then.
Old 02-21-2009, 07:33 AM
VictoriaVette
That makes since and I would have to agree.
To How Much Does It REALLY Weigh??
Quick Reply: How Much Does It REALLY Weigh??
