Aluminum A-arm GIVE AWAY from Speed Direct
Premium Supporting Vendor
We are announcing our aluminum control arm give-away. Enter by submitting a photo of your Corvette and entry form online at http://cmc.speeddirect.com/contest.asp?&url=contest/ We will be giving away a set of our aluminum upper control arms outfitted as you like including performance ball joints and polished finish (as depicted in the photo). Complete rules and details are at the link above.Please keep the image size under 200 KB otherwise you will get an error when submitting.
Speed Direct’s aluminum control arms improve front end geometry for better handling and more stable driving. More positive caster is achieved for better straight line stability, revised roll center and a more aggressive camber gain for more cornering ability give your Corvette what it needs when using modern radial tires.
__________________
www.SpeedDirect.com
Corvette Forum Members get 10% off with code: CF10
Steeroids rack & pinion conversion kit for '53-'82 Corvettes
Shark Bite Suspension Front & Rear Coil-Overs, Aluminum A-Arms & Diff Covers, Stage Kits
Rod Links Spherical rod end clutch linkage for '65-'82 Corvettes
www.SpeedDirect.com
Yeah we're psychic. We know the winner before the contest is even over. Haha. Sorry about that typo. The winner will be announced May 15th. We will correct that right away.
Can you let me know if you received my entry. I keep getting an error after I submit. I stayed with the 25 words and uploaded a pic.
Dennis Spedale
Dennis Spedale
I tried entering but I keep getting an error:
"Request object error 'ASP 0104 : 80004005'
Operation not Allowed
/scripts/fh_upload.asp, line 49 "
Can I send you the picture?
Dennis and Buzzardz_vette please send me your info and photo to salescf@speeddirect.com What browser are you using? Do you have a firewall running that may be blocking it from uploading?
We have made several tweeks...we'll make more until we get it working like it was when we tested it. Go figure it decides not to work when we go live with it. Sorry guys but we'll get it fixed. We are getting people signed up so others aren't having the same trouble.
Good luck with your contest.
shmoky
edit: Upon resizing the picture it now works.
Ok, I think we figured out why some are having problems with submitting an entry. I looks like the image size needs to be smaller than 200 KB. So please re-size your image before submitting.
