engine casting number ID help
Old 01-19-2009, 09:42 AM
blively
blively's Avatar
Default engine casting number ID help
i have a big block that im really curious as to what it came out of and exactly what size it is.. can someone help me out and fill me in on any info? here is the casting number: 3999289 the last number could also be an 8, couldnt 100 percent tell if it was a 9 or 8.. thanks in advance for your help!
Old 01-19-2009, 09:51 AM
Durango_Boy
Durango_Boy's Avatar
I don't think there was a casting number like that that ended in '8' so I think you read it correctly.
3999289 - 454 - '71 thru '79 - 2 or 4 bolt - Some "CE" replacement blocks had four bolt main caps.
Old 01-19-2009, 10:02 AM
joewill
joewill's Avatar
you really need to post the cast date and the numbers/letters stamped on the engine right front stamping pad to get lots more information...
let us know...
Old 01-19-2009, 10:23 AM
blively
blively's Avatar
Ok I do know it has 72 Hi Perf stamped on it also. I'll have to look at the other casts and get back to you...
Old 01-19-2009, 10:24 AM
Jughead
Senior Member since 1492
Support Corvetteforum!
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
3999289....454.......71-79...2 or 4 bolt, some "CE" replacement blocks had four bolt main caps
http://www.mortec.com/bbc.htm
I think the Hi-perf was on all non tall deck big block.
Old 01-19-2009, 11:47 AM
blively
blively's Avatar
Ok awesome! Thanks for the help guys!
To engine casting number ID help
Quick Reply: engine casting number ID help
