Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-05-2008, 04:47 PM   #1
DREGSZ
CF Senior Member
DREGSZ's Avatar
Default L88 vs LT1/BBC hood scoop 68 -72
Hi All,
A friend pointed something out to me. I hadn't really noticed before.
I always thought of the BBC hood scoop as not the same as the LT1 scoop but the bigger dip without the bridge or center bar as I will now call the L88 hood Scoop.
I hadn't realized that the stock 427/454 scoop was the same as the LT1 scoop, (Is it the same?)
Was the bigger L88 scoop factory correct on any car?
Was there a difference between the LT1 and 427 or 454 factory hood scoops?
http://www.zercustoms.com/carparts.p...0&t=1163510153
http://www.ecklers.com/product.asp?p...5&dept_id=1737
was this a factory "stock" design?
http://www.ecklers.com/product.asp?p...3&dept_id=1737
DREGSZ is offline   Reply With Quote
Old 12-05-2008, 05:59 PM   #2
Alan 71
CF Senior Member
Alan 71's Avatar
Hi,
I believe the L-88/ZL-1 hood was for real, came from St.Louis, and different than the normal BB/LT-1 hood. It has a different 'bulge' and 'cowl- induction'.
Regards,
Alan
Alan 71 is online now   Reply With Quote
Old 12-05-2008, 06:03 PM   #3
razman
CF Senior Member
razman's Avatar
Rick Spear
the LT-1 hood and the big block c3 hood are the same hood. at least that is my understanding. the L88 is different with a larger scoop after the louvers.
razman is offline   Reply With Quote
Old 12-05-2008, 06:05 PM   #4
wfo76
CF Senior Member
Link 1 - L88 scoop
Link 2 - L88 hood (factory 68-72 design, 'short' hood works with 68-72 only, 'long' 73-up version also available)
Link 3 - BB/LT1 hood (68-72 only)
wfo76 is offline   Reply With Quote
Old 12-05-2008, 08:11 PM   #5
dmayhew
CF Senior Member
The only difference in thr 427 / 454 hoods from a LT-1 hood are the emblems on the big block hoods for the motor size.
A true original LT-1 hood would have no holes drilled for the 427 / 454 numbers.
The LT-1 has the double pin strip which I think does a great job outlining and hoghlighting the buldge.
The L88 hoods or taller scoop hoods were a factory hood. The air filter is in the hood and as said it offers cowl indunction.
A must to make the HP those monsters made.
David
dmayhew is offline   Reply With Quote
Old 12-05-2008, 09:09 PM   #6
Jughead
Senior Member since 1492
St. Jude Donor '09
Support Corvetteforum!
Jughead's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2.That which does not kill me will probably hurt like hell. 3. Islam is the enemy.
Send a message via AIM to Jughead
Underside of the L-88 hood. It's called an air chamber.
Click the image to open in full size.
Jughead is offline   Reply With Quote
Old 12-06-2008, 12:32 AM   #7
Vettebuyer5869
Moderator
Vettebuyer5869's Avatar
Location: About 1100 miles from home. (The World Champs)
The 427/545 hoods also have 2 chrome trim inserts. None on the L88.
The "long" L88 hoods, designed to eliminated the wiper door on 68-72 and also used on later cars, are custom, non-stock hoods.
Vettebuyer5869 is offline   Reply With Quote
Old 12-06-2008, 11:52 AM   #8
SBR
CF Senior Member
SBR's Avatar
Here is a pic of a factory L88.Click the image to open in full size.
SBR is offline   Reply With Quote
Reload this Page L88 vs LT1/BBC hood scoop 68 -72
Tags
1970, 68, 6872, 71, 72, corvette, dimensions, hood, l88, lt, lt1, racing, scoop, scoops, scoups, summit
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
