1982 Corvette Radiator
Old 11-23-2008, 08:09 PM
cpmman
cpmman's Avatar
Default 1982 Corvette Radiator
Where is the best place to get a replacement radiator?
What price should I expect to pay as the prices seem to go from $163.00 eBay for a 3 core up to 299.00 at Zip.
Anything special need to be done to replace it?
Appreciate the help..
Old 11-23-2008, 08:49 PM
Durango_Boy
Durango_Boy's Avatar
I have bought a generic after market radiator before that was supposed to fit my car, and it didn't. In fact, it was crap. If you are going to buy a new radiator I suggest you take the plunge and upgrade to an aluminum, and get one from DeWitts here on the forum. Honestly one of the best mods I ever did to my car and it was easily worth every penny. True direct fit drop in installation, and it cools way better than my stock one did and SO much better than the crap one I bought off of Ebay.
Old 11-23-2008, 09:03 PM
Jeffery73
Jeffery73's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13
An excellent product from an excellent vendor. It was a perfect fit in my car.
Here it is bolted up to the core support and ready to drop back in.
And it the car. Looks pretty sweet.
Old 11-23-2008, 09:04 PM
79 vette head
79 vette head's Avatar
St. Jude Donor '10
try www.teamradiator.com paid $210. a few yrs. ago for a 4-core rad.
Old 11-24-2008, 12:33 AM
rexx78
rexx78's Avatar
Pull out the old one and take it to the rad shop. Why do you need a new one?
Old 11-24-2008, 06:03 AM
mtwilsonboy
mtwilsonboy's Avatar
When I did my car mt radiator needed attention too, but I thought some of the radiators I looked at were junk so I took the original to the shop and had it rebuilt for 299.00. No fitting issues, and my car always run cool plus I still have the original radiator. My .02 cents.
Old 11-24-2008, 07:44 AM
cpmman
cpmman's Avatar
Would like to upgrade to aluminum but I really want to keep the stock look in the car and it always ran nice and cool since it has the stock motor in it.
Old 11-24-2008, 07:47 AM
cpmman
cpmman's Avatar
It just stated leaking on the bottom driver side and it appears to be the original. Having it re-cored seems to make the most sense.
What is the best procedure for taking it out of the car?
Does the hood absolutely need to come off to remove it or will it slide out with the hood on?
Old 11-24-2008, 07:49 AM
cpmman
cpmman's Avatar
$299.00 seems like a lot for a re-core...Did you have it restored or just re-cored?
Old 11-24-2008, 07:54 AM
Durango_Boy
DeWitts radiators can be painted to match the stock black before they leave and get shipped to you. Install one of those and no one would know the difference.
The radiator can be removed and installed with the hood on the car but it's harder to do.
Old 11-24-2008, 10:24 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
Originally Posted by rexx78
...Pull out the old one and take it to the rad shop....
Old 11-24-2008, 12:13 PM
cpmman
cpmman's Avatar
Are the 82 radiators a 3 core or 4 core?
Old 11-24-2008, 05:09 PM
rebc3
rebc3's Avatar
ive got a 78' - 4 row rad, with about 800-900 miles on it that i just recently pulled to install an aluminum rad. pm me, its yours cheap. youll even get the old electric fans
Old 11-24-2008, 06:34 PM
79 vette head
St. Jude Donor '10
thats an offer you shouldn't refuse....
Old 11-25-2008, 08:24 AM
cpmman
cpmman's Avatar
Will a 78 Radiator fit an 82 without and modifications to the car or radiator? Is it an exact fit?
Thanks for the reply and information.
Old 11-25-2008, 08:40 AM
Durango_Boy
Are they both automatic transmission cars?
The '76 through '82 should be the same with the exception of the transmission fluid tank bungs for the automatic transmissions.
Old 11-25-2008, 11:17 AM
cpmman
cpmman's Avatar
The 82 is automatic for sure..niot sure about the 1978 yet.
Is there a transmission line going into my 82 radiator?
To 1982 Corvette Radiator
Old 11-25-2008, 11:21 AM
Durango_Boy
Yeah there should be two lines. A 'to' line and a 'from' line. They are metal lines from the transmission itself.
Old 11-25-2008, 12:01 PM
cpmman
cpmman's Avatar
What is in the lines..transmission fluid or coolant?
Old 11-25-2008, 12:20 PM
Durango_Boy
Transmission fluid. The lines carry hot transmission fluid from the transmission to the radiator, where there is a tank built into the side of it. The fluid is cooled and returned to the transmission by way of pressure from the transmission pump that sends fluid to the radiator.
Quick Reply: 1982 Corvette Radiator
