Baby It's Cold Outside - Keeping Warm This Winter
Senior Member
Received 2,031 Likes
St. Jude Donor '10
My wife, that lovely woman that has granted me a new garage lift and garage makeover, has agreed we should check in to heating the garage this winter to make it more comfortible for me to work out there. I am truly blessed to have this woman in my life and plan to slip an extra nice gift under the Christmas tree to her this year.
Okay, so as the poster of the "Show Me Your Garage" I am now asking if any of you can show me pictures and or offer me advice on heating my garage this winter. Short of a gas furnace addition what have you done to keep things warm? This is honestly not a post for everyone, not everyone lives where there is a winter to deal with, but for those dealing with the cold could you, better yet would you please share your thoughts.
Thank you in advance.
David
David
I'm kind of interested in this too. Simply, I just have to put up with the cold with extra layers and gloves. It sucks when you're under a car and your breath makes it hard to see the bolt you're trying to turn.
Received 4,592 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Probably not the most cost effective method but I installed an electric blower/heater mounted on the wall. It is connected to a thermostat. I maintain about 50 degrees all winter in a 36x30 2 1/2 story barn all winter. When I want to spend time out there I just crank it up and it will be in the 60's in no time. On average it costs me about $120/month in the coldest months December-January-February and March. Cars-TV-Stereo-beer and cigars
This BTU calculator will help you figure out how much heat you need for your needs. I would go with electric so you don't have an open flame, no venting to the outside, no carbon monoxide and no condensation on everything. I just installed the Dayton and had an electrician run 240V to the garage ($325).
http://www.heatershop.com/btu_calculator.htm
Here is where I got my heater. I needed two for my 3 car attached insulated garage with a 10'6" ceiling.
http://www.air-n-water.com/product/G73.html
Senior Member
St. Jude Donor '10
Now, for those 240V lines...need an electrician. Where is that phone book.
Thanks again
David
Senior Member
St. Jude Donor '10
Also, and I just thought of this, do you have a floor covering of some sort you are using to get up off the concrete?
Thanks for the info.
David
Perfect, thank you. I have a three car attached garage that is insulated but does have some leakage around the doors. These two links suggest I needed 32,000 BTU's which, if I calculated correctly, could be handled by two of the units you bought as well. A cozy garage would be very nice. Do you have a picture of the install you did that I could see?
Thanks again
David
Thanks again
David
It's also nice to have them up around the ceiling so they don't take up any valuable space in the garage. They have a thermostat **** on the front and in order to reach it I drilled a hole in the **** and installed a screw so I can turn it with a stick from below.
I insulated and put drywall up on my garage walls and ceiling. I also installed insulted garage doors and then added the Dayton electric heater. I keep my garage around 50 degrees and turn the heat up when I'm going to work in the garage. Sealing the garage doors will help alot with keeping the cold air out during those windy wintry days.
Cruise-In VIII Veteran
St. Jude Donor '06
I have a 3 car insulated garage (with leaks around the doors as well).I put up a 45K BTU hanging heater from Grainger 15yrs ago and still kicking. I usually leave the heat set to 60 and bump it up to 65 when working out there.
Hope this helps.
Tim
Hope this helps.
Tim
Putting some kind of synthetic flooring down sounds like an excellent idea. Lots of heat sucked up by cold concrete. Anyone having such flooring care to elaborate on their insulating properties?
Senior Member
St. Jude Donor '10
David
Senior Member
St. Jude Donor '10
Did you do anything to the floor or did you stick with concrete?
David
Senior Member
St. Jude Donor '10
I wondered how long it would be before someone living in a warm climate managed to weigh in on our cold winter situation.
Can't blame you for not knowing about our pain. Of course we have an excuse 4 months a year to work on the car in the garage.
Is that Rachel Ray cooking for you this Thanksgiving? Nice!!!
Do you air condition your garage for the summer?
Thanks for sharing.
David
Thanks for sharing.
David
St. Jude Donor '08
Thanks for sharing.
David
Thanks for sharing.
David
Absolutely I have AC in the garage - it's the only way I can stand to be in there fron June - September. I figure about anywhere you live there is a 4 month span where it's either hot, cold, or real wet (except for those lucky guys in San Diego) so it's all good
Senior Member
St. Jude Donor '10
Yes - it's Rachel Ray - I try to have fun over the holidays with my avatar (the rest of the time I use an Arizona route 66 road sign). I grew up in the greater Cleveland area so I know your pain - I was just having some fun.
David
I installed a Modine HotDawg. Its a forced air gas fired garage heater. Vents sideways so no chimney is needed through the roof. Works great. Not even a blip on the gas bill with layover at 55. I think its 70k BTU and its a two-car garage with a 12 ft ceiling.
My garage floor floats on styrofoam and its pretty easy to heat in the winter.
When I had to worry about the cold, I bought an oil furnace from a guy used for $300. It heated a 1500 sq. ft. shop with no problem. I also had a double 55 gallon drum wood heater made from a kit in one of my other shops. If it was 15 degrees outside, I could get it up to 90 in the shop with three windows open! I just had to stop throwing wood on the fire when the lower drum started glow red.
I'm glad I don't need to worry about stuff like that anymore. Although, it is chilly today, we're only supposed to get up to 65 or 70 today!
Wakefield, MA here...
I bought a used convection-type propane heater (two 20 gallon tanks take me thru the winter - easy, no electricity). I keep a window open about 6" when it's on, it gets the garage to 65 degrees real quick (11' ceilings, 600 sq ft) - paid $50 for it off Craig's list...
I shut it off once the garage is heated up and I can stay out there for hours. I also have insluated/finished walls and insulated doors.
Next up a lift and a ceiling mounted NGas unit.
Have fun!
Dave
74 L82 Roadster
Have fun!
Dave
74 L82 Roadster
