Jacking up a C3 for 4 rim removal??
1st vette I have owned...
I'm about to jack up my '72 and remove rims and tires. I am sandblasting rims and getting new tires.
Question.... It is pretty obvious were to jack up the front end for removal of front tires. Is it safe to jack up the back end from the middle of the rearend for removal of rear tires?
Do you jack up front, then back or left side then right side??
Also where is the proper placement for jack stands? Along the frame rails under driver and passenger doors?
Sounds like you are on the right track...
Lots of folks lift the front by the front cross member... that's why so many are dented there. If you decide to do this, I recommend using a short 2X4 (aligned fore and aft to distribute the load) between the jack pad and the cross member.
You can lift the rear from the center as well, you'll just need to clear the spare tire carrier. I also recommend using a short 2X4 between the jack pad and the center of the spring.
Jack stands go on the frame in front of the rear tires and just below the door hinge area where the frame is horizontal.
I would recommend loosening the lug nuts before you lift it, as it can become unstable on stands trying to break the lugs loose... unless you're using an impact wrench of course.
Good luck... GUSTO
Good luck... GUSTO
1 Post
Place the jack stands where Gusto recommends.
However, I would recommend lifting one side of the car and placing jack stands, then lifting the ther side and placing them. I have done this multiple times with no problem. I don't like lifting from the center of the spring due to how the rear diff is bolted to the back of the body.
Good luck and be careful.
Dino
Dino
I too lift mine one side at a time. Just be sure not to lift under the transmissioin crossmember either, or you'll dent that. I then place jack stands under the frame right at the edge of where the frame is straight, front and back.
