Easy Carb-To-EFI Conversion
Hi,
Does anyone have any experience with this Easy Carb-To-EFI Conversion set ?
http://www.fastmanefi.com/products.htm
/John
/John
Man, that's a bunch of $$$ just to replace a carb. Why not just put a Chevy TPI system on it from a mid-80's Camaro?
$1900 ain't bad. I did a Holley Pro-jection for about that. EZ is the key. Any factory fuel injection will need major tuning on the memory. Mine is EZ laptop tuning, but this doesn't even need that. Just drive.
Bee Jay
Bee Jay
I am going to use the Holley TBI with the 950 commander ECU. after talking to Bee Jay about his set up and doing a lot of research about fuel injection I found it to be the most cost effective set up out there. It provides good drive ability better fuel economy than a carburetor and it's completely programmable with a lap top. It is not as complex or expensive as a multi port set up. I was going to use a TPI but found out that it would probably not breath at high rpm for my 383. I bought mine from Scroggins Dickey parts center for $1509. http://www.currymotors.gmmotors.com/...dySystems.aspx
Check out the Holley's web site you can download the instruction manual before you buy it to see what it takes to install.
http://www.holley.com/950-24S.asp
Bee Jay
CI 5 & 8 Veteran
Bullshark
