Comp Camshaft
Comp Camshaft
i want to install a comp 280 camshaft in a 350 small block. Mainly for the engine lope (sound). Will this cam affect the vaccuum and will I have to have a stall converter?
Is there someplace in the forum that will tell me how to install the camshaft while the engine is in the car?
I appreciate any information you can give me.
Changing the cam is not a real big deal. Picking the right cam is! Do the appropriate research.
You will have to remove anything that is in your way. Shroud,rad condenser. I think you get my drift.
Removing the hood may help,also.
First, selecting a cam based on what it sounds like, isn't very prudent. Tell us about your car,..the rest of the engine, gearing, tranny, A/C, vacuum requirements (it's a Vette, almost the whole car is seemingly vacuum operated), and your goals.
A number of years ago I installed the Comp Cam 280 in my '74 small block. BIG mistake. Sure it sounded great, but was a "bear" to drive in town. I have a 4 speed in mine and had to drive it in first gear under 30 mph. Vacuum was way low; my car has A/C and is vacuum operated and it had trouble operating. Darn thing wouldn't idle under 1,100 rpm. I installed the complete Comp Cam valve train and had no trouble twisting it to 6,000 rpm, but how often do you do that. I ran it one summer and then pulled it apart and changed the cam. I'm running a Comp Cam 268XE now. Much nicer to drive. I've included a sound clip which I had made for a Forum member that wanted to hear how Mike Allen's turbo mufflers sounded.
Mike
Mike
The 268 is a nice cam for a stock L-48. I have it my 80, not the XE version. It will lope nicely at idle and you can get the idle down to 500 RPM...I call it the $1000 idle. I also put heads on the Vette when the cam swap happened.
I've got a 69 four speed car with 4.11 gears no P/B's that I'm getting ready to rebuild the bottom end on. Probably a cast kit 9.5 to 1 compression and aiming for 400 HP. I've got a fresh set of 64cc Sportsman II that have been ported and polished, Edelbrock RPM manifold, Holley 750, Hooker sidepipes and a Clay Smith Cam almost identical the the Comp Cams 280 all sitting on the shelf ready to go in. Any recommendations or other considerations I may not be thinking of ?
Vegas,..you'll love that cam. I've run it in both SB's and BB's and with at least 3.73's (you have 4.10's) the cam is perfect for the street if you're running a flat-tap hydraulic. I usually go with 10:1 CR but with your iron heads, 9.5 should be fine. It has just enough vacuum in a 350 (11-12hg) and plenty in a 400 (14-15hg).
You won't be disappointed.
But with less compression and gearing, the 280 wouldn't be the choice.
Good luck!
Good luck!
I used that 268XE in my 77 L-82. Its the 3rd cam I have tried and I'm sticking with it. Nice lope, good idle, great power...I'm totally satisfied. Like most others I also changed the heads and upped the compression.
The 268 xe is a great cam as i have it in my car now.The thumper line might be the way to go.
So all you guys are recommending a cam change for this guy with out any other mods first? Or in conjunction with??
A cam change without allowing it to breathe is a waste of time,money and effort.
Most everybody I know is running from Comp's XE line,..me included. Do a search, "wiped XE lobe" on this site and the others: www.camaros.net www.chevelles.com www.novas.net
...and you'll be reading about failures for days. I believe the XE lobe ramps are too aggressive for a flat-tap cam.
And after a lobe is wiped, the engine has to be pulled and torn down.
Plus, I'm no fan of dual pattern cams in a built engine with free flowing exhaust. Here's some good reading regarding dual pattern cams:
http://www.camaros.net/forums/showth...e+dual+pattern
I think you'd be better off with one of the tried and true older, single pattern grinds.
FWIW
FWIW
