Rear Wheel Bearing Assembly
I need to replace the right rear wheel bearing and spindle on my 1975 vette. I am planning on buying a new rear wheel bearing assemble from one of our supporting vendors.
My question is can the wheel bearing assembly be installed on the trailing arm in one piece, or does the flange have to be removed in order for it to fit through the trailing arm.
I am looking at an exploded diagram in one of the catalogs, and cannot determine if the flange and inner bearings need to be removed in order to mount it on the trailing arm. Since the assembly is already put together, and hopefully the end play is adjusted, then it seems to defeat the purpose of this if it has to be taken apart to be mounted in the trailing arm.
I have more than 1/2 inch of play in the spindle/bearing now. I can move the rear wheel from 12 o'clock and 6 o'clock position by 1/2 inch or more, and can visibly see the flange moving up and down. And a very bad grinding sound coming from the rear end so I know it is time for a new spindle and bearing.
Thanks for the comments and suggestions.
KDF
KDF
Its more involved than simply replacing the bearings like on the front wheels.
http://forums.corvetteforum.com/show...=rear+bearings
Ken,
Scott is correct, but I think you knew that from your question. If you are trying to change the wheel bearings without removing the trailing arm, it can be done but you will need to install the flange after setting up the bearings and mounting the support back on the trailing arm. You'll need the setup tool to do this.
This is the way I did it and it worked out ok. It is a little harder than removing the TA though. I have the setup tools if you don't want to buy them. Drop me an IM.
Best to have a pro set them up, my 75 spun a rear once, took out the bearing retainer and spindle. I had a Chevy mechanic set up the bearings and then I disassembled to install on the car. Worked great!!
If you get something like this:
http://www.zip-products.com/Zip/prod...73B980CD92B0CE
it will bolt directly on to the arm. I've replaced both of mine w/these, and no problems so far with 15k miles of daily driving.
I recently ordered the Duntov Corvettes rear wheel spindles, complete bearing kit for what I think is a great price. You can also get the entire trailing arm assembly - arm,spindle, bearings all put together for about $540. I was very satisfied with their products.
The flange ( I think your talking about the complete hub). You have no choice in removing it with a puller, its the only way you can replace the outboard bearing. You can easy make a puller with a thick piece of steel, some threaded rod. The set up tool is very handy, but you don't need it, you may have to remove/install a few times to get the good measurements. This all depends on your abillity to do your own work, the easiest way is by far to drop it off and pick it up at the end of the day,, and don't forget your wallet.
A forum member has even offerd to lend you some tools !! go for it !
I am not planning on rebuilding the wheel bearing assembly myself, but am going to buy a completed assembly. I did find some information at VANSTEEL website about removing the rear wheel bearing assembly.
http://www.vansteel.com/index.cfm?fu...home&pageID=11
I am wondering know if it would be easier in the long run just to remove the entire T/A assembly and have it sent for refurbishing. The car is in the garage while I make a list of what I need to do, or buy.
kdf
kdf
KDF
kdf
1967 Pedal Car Champion
Here comes the Admin hammer!
(Admin does not like folks responding to 14 year old threads. Best to start a brand new one with a link to this one if the old conversation is pertinent.)
It was interesting to read my thread from 14 years ago. I still have those cars, and was surprised at how much I learned from CF in such a short time.
kdf
kdf
Michel B (06-29-2022)
Same for me,, this forum was so helpfull with my restoration,, I too still have the car and now its my son who is injoying it LOL
