driver side door handel not working
I we to open the car today and the exterior door handel isnt working at all, it only goes down about half way then stops DEAD about where it normally engages the latch mechinism, Ive tried all kinds of things to get it to work, its almost like something got under the handel itself and its preventing it from going down. the inside handel works fine, just the exterior is all jacked up, anyone have this preblem before?
Miles
Miles
The door mechanism has gotten sticky (lack of grease) and the actuation rod has bent. You'll have to take the inner panel off and see if you can wiggle in there enough to straighten the rod out and lubricate everything well. If that turns out to be the case, you'd better do both doors. [note: if you can't open the door from the inside either, something's broken or come loose in the mechanism.]
does anyone have a picture of the mechinisim I should be looking at?
Miles
If I remember correctly the inside handle and outside handle had different rods connecting to the mechanism. My 69's passenger side wouldn't open from the outside until I connected the outside rod back to the mechanism. There is a pin or clip that holds in on, make sure that isn't broken or missing. Hope this helps.
-Shark Mann
-Shark Mann
