68 wiper motor
Old 10-19-2011, 04:13 PM
steg
steg's Avatar
Default 68 wiper motor
Does anyone out there can recommend where I could either have a wiper motor rebuilt or try to buy a used one that works. Any suggestions out there? thanks
Old 10-19-2011, 04:40 PM
MelWff
MelWff's Avatar
Received 1,817 Likes on 1,606 Posts
this is one of the supporting vendors
http://willcoxcorvette.com/product_i...ducts_id=22443
Old 10-19-2011, 09:17 PM
DZRick
DZRick's Avatar
Have you bench test yours to be sure the problem is actually the motor?
http://www.youtube.com/watch?v=XpkbCGkFaJs
Old 10-19-2011, 09:52 PM
shmoky
shmoky's Avatar
VERY GOOD ADVICE HERE.
shmoky
Old 10-22-2011, 09:31 AM
steg
steg's Avatar
yes, I had it tested..the motor is dead
Old 10-22-2011, 03:44 PM
DZRick
DZRick's Avatar
Had it tested or tested it yourself using Willcox'e video?
I only ask because I know of someone that had their motor tested by 2 different mechanics that told her it was toast. I sent her the link to Willcox's video and she tested it her self and found that it worked.
That said Willcox does sell them or you might get lucky like I did and find your local auto parts store can get you one.
Please take this advise and test the new motor using that video before installing it.
Also take the rubber mounting washers and the connector off your motor before turning it in for the core charge because the new motor won't have them.
BTW, where are you located?
Good luck.
Old 10-22-2011, 06:55 PM
68/70Vette
68/70Vette's Avatar
The 68 wiper motor is electrically significantly different than the 1969 and up motors.
Old 10-23-2011, 02:59 PM
steg
steg's Avatar
Good luck.
I had the motor tested by a mechanic...I am located in Rhode Island. I will check it myself through the Willcox video. Thanks..I'm located in Rhode Island
Old 10-23-2011, 03:43 PM
mandingo214
mandingo214's Avatar
You can also "bench" test it while attached to the car. Just make the sure the wiper door is open and you disconnect all the connections going to the wiper motor. I use a battery charger to provide the 12V.
If it works, great, you can test electrical connects to it. If not, you should still test it off the car.
Old 10-23-2011, 05:23 PM
steg
steg's Avatar
my thanks to all my forum friends for advice on the wiper motor.
Old 10-24-2011, 12:14 AM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Well good deal.. The 68 motor is a different bread for sure.. and in most cases as Rick indicated, even the best mechanics don't understand it.
You can test on the car.... and it was mentioned by Mandingo to make sure you have "ALL" wires disconnected from the motor, the wiper door open and.... you have water on the windshield!
For me, I just yank the motor out.. it is pretty easy to do and it takes the car out of the equation.
If you do find one at a local parts house.. or buy one of our motors, be sure to remove the three wire connector before giving up the core. It won't come on a newly rebuilt motor no matter where you get it!
Glad to see the video still has some puff left in it..
Willcox
Old 10-25-2011, 08:35 PM
steg
steg's Avatar
Willcox
I'm going to check that video, thanks to all
Old 10-26-2011, 11:09 PM
0Willcox Corvette
Former Vendor
Good Deal.. post back what you find..
To 68 wiper motor
Quick Reply: 68 wiper motor
