1970 454/390 Hp Vs 1972 454/270 Hp
What is the reason for the drop in horsepower from 1970 vs 1972 Big block? Was it just the different way of rating Horsepower or was it due to the compression difference? Or were there other factors as well?
St. Jude Donor '08
combination of both, in '71 the HP was 365 gross, 25 HP less than the '70s 390 gross, due to lower compression (from 10 to 8.5), and in '70 the the same gross 365 HP was converted to 270 HP, but technically, they are the same engines, well, still there are some people that they will say in '71 it was 285 net due to a better cylinder head flow.
Because the 454`s are actually smog engines and they started in 1970 reducing HP available in the 70 BB Vettes. In 1972, it was actually worse to finally where the BB`s were dropped completely except for over the counter off road LS7 454`s. That particular engine was sup post to have been available for the 70 model run. It never happened. The exception was a one year high HP LS6 454 but only available in a Chevelle. Fuel, omissions, and foreign oil {Arabs} screwed the 70`s right up. And the GD "greenies' are still at it today..
CF JASOC Member
NMT1957,
The reason for the difference in net horsepower ratings between the '71 model at 285 hp and the '72 model at 270 hp is two fold. Further recalibrations were done to the quadraject carburetor and retarding of the ignition timing further from 4 degrees to 8 degrees.
The gross rating for the 1972 Corvette LS5 is 350 hp.
Using the matching block/heads/intake...
What Mods could be done to increase the HP on the 72-454 with today's available parts?
Maybe a 770cfmStreet Avenger Holley Carb probably will help...
Then what???
Nothing radical.... just a reliable increase for fun driving and strong running.
Then what???
Not much you can do unless you're willing to go into the motor. The stock Q-jet has more than enough flow, no gain by going to a holley. Headers will help, that's about it. Some gains by swapping the cam but you don't have the compression to support anything radical.
The LS4 & LS5 need compression and a good intake to come alive. After that a decent set of heads and cam and you'll easily pass the 500hp mark.
MISTERZ06 (05-18-2017)
I had my heart set on buying a 1970 Big Block because of the 390 HP rating, but due to limited availability and higher price I may go to a 1972 Big Block 270 HP. It kinda breaks my heart so I just wanted to know how much difference there really was between the two motors. Im sure the 1972 will have plenty of HP , its just the idea of it I have to get used to. Thanks.
Slowly save up for some engine work... or go heads and cam for the HP.
I'm considering a 72 BB too... In due time, I'd potentially be willing to let a qualified person do a lil' engine work for more HP without breaking up the matching numbers or damaging the original parts. Nothing radical but better than 72's stock setup numbers.
I'm never racing or running the car down the strip anyway... but it would be cool to know you have created a better HP situation for the car. The sound of power and feeling when BB drives by is just kickazz.
NMT1957,
The 1972 Corvette LS5 engine has a net torque rating of 395 ft lbs. The strongest L78 396 engine only had 410 ft lbs of torque, and thats at the gross rating!
You just need to buy a '72 Corvette LS5 WITHOUT a/c, look for a M20, 3:36 ratio drivetrain, the car will feel plenty strong. If you can find an M21, 3:55 even better! You won't need to get into the engine.
Yankeededandy (04-20-2016)
NMT1957,
and 8.5:1 compression.
And it has A/C, 3.08 rear and M20. Cruises down the highway at 70 running 2500 rpm.
And I can smoke the tires (radials, not bias ply) anytime I want. Completely stock.
cc
Last edited by CCrane65; 06-16-2008 at 11:26 PM. Reason: Console plate does not have HP on it.
You could also consider having the stock intake ported. Most standard hot rodding tricks will work as long as you keep in imnd the clearance issue.
cc
my 72 big block is definitly faster than my 70 bb was. maybe because i got 68 heads that have more compression. anyone know more about this? also my 72 is a auto, 70 was a 4 speed. with a newly rebuilt engine.
I would say my '72 BB Auto will set you back in the seat off the start but the acceleration is not startling as is not the top speed.
The new Nissan Skyline GTR now that's something else.
I didn't buy my car to goof off, just for cruising.
You just can't beat the rumble of a Big Block with that unique sound.
NMT1957,
450-500 HP is child's play with a 454 if you'll up the flow and compression with some aftermarket heads (Brodix RR-BB-O?) and add cam in the 230 - 240 @ .50, then run some 1-7/8" long tubes. Your cam choice will be determined by rear gear, tranny, and your goals.
Now the bad news. I'm not sure the stock IRS will hold up to 500 HP especially if you run sticky tires.
Good luck!
Good luck!
This and other references in this thread to increasing compression in the LS5 to gain HP. Is this referring to the 71 and beyond LS5 wherein compression was dropped from that of the 70 454?
I wouldn't imagine that you could squeeze much more in the 70 if you're running 93 octane?
Without sending the original block to a machine shop or opening up more room under the hood, it seems the options for improving the intake and cylinder heads on the 70 BB are limited if I'm interpreting all this correctly.
So far as max compression goes, I thought I read somewhere that you can get around some of this with a modern cam?
The 70 has a closed chamber head. I think they went to open chamber in 71. Many people prefer the open chamber anyway.
