Can anyone identify these rally wheels?
St. Jude Donor '04 & '05
I was doing some garage cleanup on Friday and pulled out these two old rally rims from a deep dark corner. Not sure what they originally came on and was hoping someone can help decode the numbers.
The first is a 14 x 7 rim marked "K-1-9" in the center by the lug holes. By the valve stem it is marked:
K-1-0 1 (valve stem here) 28 YM
Here's a pic:
The second rim is a 15 x 8. Marked K-1-8 by the lug holes and by the valve stem:
K18 8 (valve stem here) 20 AG
And here's a pic of the second rim:
TIA to whomever can help.
Here's a pic:
...if I'm remembering correctly, the K-1-9(or 8), should be Kelsey Hayes, Plant #1, 1969. Same thing except 1968 for the second wheel.
First wheel should be Jan 28, 1969. "YM" is the model of the wheel. Not a '69 Corvette wheel which should be "AZ". Maybe Camaro, Monte Carlo, Chevelle SS wheel.
Second wheel should be August 20, 1968. This "AG" is a 1968 ONLY Corvette wheel. It should also be a 15 x 7 inch wheel.
Thanks for your replies.
After a bit of searching online I found that the YM wheel is likely for a Chevelle. As for the AG wheel, I was going to keep it as a spare for my 75 coupe but after finding that it's a 68 only vette wheel and the wrong size, I guess I'll see if anyone wants/needs it for a restoration project.
During my search I found the following info on Rally Wheel codes and thought I'd add it here for someones future reference. FWIW.
Thanks once again for the info guys!
GM Rally Wheels
XA 14X5 B-3 1/2 67 Chevy II with drum brakes
DA 14X5 B-3 7/8 67 Chevy II RALLY with disc brakes
DG 14X6 67 Camero & Chevelle with dics brakes
XB 14X6 B-4 3/8 67 Chevelle SS, 68-69 Chevelle with F-70 Tires, 70 Chevelle
XN 14X6 B-3 3/4 68-69 Camero & Nova with drum brakes. Different shaped outer
AE 14X6 B-4 3/8 70 Chevelle Station Wagon
XG 14X6 B-3 7/8 68-69 Camero with dics brakes, 68-70 Chevy II/ Nova with disc brakes, 69-69 El Camino without disc brakes. Wider drop center than normal
DE 14X6 B-4 3/8 71-72 Nova & Chevelle, 6 hole wheels
YW 14X6 B-4 3/8 Exactly like XB, may have come on same cars
YJ 14X7 B-4 3/8 69 Camero/ Chevy II L72- ZL1, 70 Nova
AV 14X7 70-72 Camero, 71-72 Nova, 6 hole wheel
XT 14X7 L72- ZL1 Non Rally Wheel
YA 14X7 B-4 3/8 69 Chevelle SS Wheel
AO 14X7 B-4 3/8 70 Camero &69 Chevelle SS Wheel
DB 15X5 67 Passenger Cars with disc brakes.
DF 15X6 B-4 1/16 67-68 Camero Z28
DC (BIG) 15X6 B-3 1/2 67 Corvette, No other stampings on rim
DC 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (early models)
FI 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (later models) Rivited instead of welded together
YS 15X6 B-3 1/2 68-70 El Camino
FW 15X7 B-4 1/4 71-up most any GM
AG 15X7 B-3 3/4 68 Corvette (will take 15x8 Beauty rings)
YH 15X7 B-4 1/4 L72- ZL1 Z28 Rally 69 narrow drop center
AD 15X7 B-4 1/4 L72- ZL1 Z28 Rally 68 wide drop center
AV 15X7 70, 71, 73 CAMARO Z28 5 spoke wheel
AZ 15X8 B-4 69-82 Corvette
Here are a few extra notes:
* All the rally wheels made in 1967 have big marking letters, no date code, a little bit different shaped center and slightly bigger holes in the center.
* The 15x7 beauty ring will go on all the 15x6 wheels.
* All the hubcaps interchange with each other.
GM Rally Wheels
