How Do You Polish Cloudy Plastic Lenses to Make Them Clear Again?
Old 04-16-2008, 12:37 PM
Wuttin
Wuttin's Avatar
Default How Do You Polish Cloudy Plastic Lenses to Make Them Clear Again?
When I washed my gauge cluster and tach lenses with mild detergent and water (nothing harsh) they ended up slightly cloudy. Not enough to make them unusable, but cloudy nonetheless. They were dirty, but not cloudy before I cleaned them. I didn't scrub or use anything abrasive so I was pretty shocked. These folks sell products to correct this:
http://www.janvil.com/plastic_polish.htm
I saw on Eclker's site that Zaino also offers a plastic polish. I expect most of the big polish companies have something comparable.
Any experience with this or other reccomendations on how to make them clear again? They are in great shape otherwise so I'll just live with it if I can't fix them, but it sure would be nice...
Thanks, Steve
Old 04-16-2008, 12:40 PM
mdj21
mdj21's Avatar
could it just be hard water stains?
maybe try rewashing them in distilled water.
Old 04-16-2008, 12:50 PM
toddalin
toddalin's Avatar
Received 1,167 Likes on 486 Posts
I've used The Wax Shop Products Safe Cut with good results.
Old 04-16-2008, 12:52 PM
crazywelder
crazywelder's Avatar
Some plastic polishes can be to course. Toothpaste was popular a few decades ago. I have found the safest polish to use is Meguiars Machine Glaze #3. Use by hand with a soft Kleenex or a microfiber towel. The results depend on the depth of the scratches, so you may have to polish several times to get good results. But it will work very well without adding scratches.
Old 04-16-2008, 12:59 PM
rihwoods
rihwoods's Avatar
Mequiars Mirror Glaze 10 works good as well
Old 04-16-2008, 01:19 PM
Wuttin
Wuttin's Avatar
Thanks all...where do the clouds come from? The lenses are pretty much scratch free.
Old 04-16-2008, 01:29 PM
rihwoods
rihwoods's Avatar
Only thing I can think of something in the detergent caused that...I've never used detergent on gage clusters...so that is my guess..
Old 04-16-2008, 01:38 PM
crazywelder
When you clean them, use a gentle household glass cleaner and either a damp kleenex or a scrap cut from a clean damp microfiber towel. Don't use a microfiber towel that's been put in a drier, it will scratch.
Old 04-16-2008, 02:08 PM
Lon Wayne
Lon Wayne's Avatar
Default Vader Vette
When I fueled airplanes the ONLY thing the Bell Jet Ranger ranger Chopper guys would let me use to clean the wind screen (plastic of some type) was Mirror glaze not sure on the brand but is in every little FBO (airport) or even A big Airports pilot shop . you can put it on a million Dollar Heli It s the best polish Ive ever used.Came in A little gray bottle with a squirt cap.One of the reasons plastic turns color is because the plastizer that make it plyable starts to discinagrate after long periods of time since yours did it all at once i think you should be able to polish them clear again.
Old 04-16-2008, 02:10 PM
wcsinx
wcsinx's Avatar
Turtle Wax Chrome Polish works well.
Old 04-16-2008, 02:49 PM
Wuttin
Wuttin's Avatar
http://www.meguiars.com/?pro-clear-p...lastic-Cleaner
Looks like a good place to start...
Old 04-16-2008, 03:14 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Did you use any kind of abrasive pad...like Scotch-brite, etc.? That would cause your problem. To polish them properly, you need to remove the lenses. However, you can put a polymer coating on them to minimize/eliminate the haze. I like to use Nu-Vinyl on my interior panels and clear plastic lenses. It make micro-scratches invisible and protects everything from normal scuffs and abrasions. Just wipe on the 'milky' liquid and let it dry. No buffing, no mess, no peeling; lasts a long time. Great stuff.
Old 04-16-2008, 03:41 PM
Bowerss2
Bowerss2's Avatar
that sucks, i usually just stick to windex or something for cleaning the interior, i have seen someone shoot their gauges with brake cleaner, now you want to see something that clouds plastic, hahahahahah, messed them all up so bad, they had to be replaced, good luck,
Old 04-17-2008, 02:13 AM
427SIXPACK
Support Corvetteforum!
427SIXPACK's Avatar
Has anyone tried anything for the rear the plastic window of the vert top that has slightly clouded with any success?
Old 04-17-2008, 02:41 AM
V77Vette
V77Vette's Avatar
plexiglass polish at any airport was what i was going to say
windex it first to make sure its not waterstain
Old 04-17-2008, 08:05 AM
Trae1976
Trae1976's Avatar
I have used Novus plastic polish for many years with good results. I tend to use a lot more of the #2 than the others.
Old 04-17-2008, 09:29 AM
red topless gator
red topless gator's Avatar
Thanks, Steve
Try Semi-Chrome, I know you can get it at a Harley Dealer. Kinda expensive for a small tube, but I used it on my old tail light lenses and they came out like Brand New.......................LT
To How Do You Polish Cloudy Plastic Lenses to Make Them Clear Again?
Old 04-17-2008, 09:45 AM
Lon Wayne
Lon Wayne's Avatar
You got it thats the same stuff only the bottle was gray.
Old 04-17-2008, 11:35 AM
CORVETTEKARL
CORVETTEKARL's Avatar
I've used 3M Finesse-It II Finishing Material for many years with great results.
Old 04-17-2008, 12:21 PM
1970 Dave
1970 Dave's Avatar
Please explain--thats a new one for me
SEMPER FI--1970 Dave
Quick Reply: How Do You Polish Cloudy Plastic Lenses to Make Them Clear Again?
