Best Fiberglass paint stripper ?
Old 04-08-2008, 11:36 PM
Toyvet
Toyvet's Avatar
Default Best Fiberglass paint stripper ?
Was wondering what you guys use for fiberglass paint stripping that is enviromentally friendly if there is such a product ? Thanks
Old 04-09-2008, 01:23 AM
400hp427vette
400hp427vette's Avatar
St. Jude Donor '09
Kleen Strip makes a great paint remover for fiberglass must be ordered Do not and I mean do not USE kleen strip aircraft remover, Must be Fiberglass paint remover.
Old 04-09-2008, 01:31 AM
al329
al329's Avatar
Plenty of opinions here....
Citrustrip sounds the most bio friendly.
http://forums.corvetteforum.com/show....php?t=1957829
Old 04-09-2008, 10:35 AM
Manuel Azevedo
Manuel Azevedo's Avatar
The best and safest product to remove paint from our cars is called (SANDPAPER) Really it is the safest way to do it but true it is a lot of work but worth it in the end.
Old 04-09-2008, 11:02 AM
I'm Batman
Support Corvetteforum!
I'm Batman's Avatar
St. Jude Donor '07
Razor blades are popular...
Old 04-09-2008, 12:20 PM
jaclt
jaclt's Avatar
CAPTAIN LEE'S SPRA' STRIP works extremely well. I've stripped three cars with great results. I have a soda blaster and found it to be too agressive unless the car has several prior paint jobs. Take your time and do a small section at a time like the instructions say.
Old 04-09-2008, 02:18 PM
billd56
billd56's Avatar
i used a heat gun and razor blades. Worked great with minimal fiberglass damage. I found that this method worked much better than the fiberglass stripper that i used.
Old 04-09-2008, 02:57 PM
SuprJames
SuprJames's Avatar
Did the entire car that way.
Old 04-09-2008, 03:29 PM
Ron R
Ron R's Avatar
Holy crap man, you guys must have the patience of a saint in order to strip a car with razor blades.
Old 04-09-2008, 05:04 PM
68/70Vette
68/70Vette's Avatar
What kind of razor blade. I started out using an xacto knife. It works but it's going to be way to slow and dedious. Use one of those old large two edged razor blade? Seems a little dangerous to hold that in your hand. Is there some sort of a razor blade holder made especially for scrapping off paint.
My car has a thick red paint (urethane?) sprayed over primer which is in turn sprayed over a greenish-blue lacquer which is sprayed over primer which possible has the original malibu grey lacquer from the factory. I want to razor blade remove the urethane. The primer and lacquer underlayers can be easily (!!!!!) wet sanded off. I've wet sanded lacquer painted corvettes before - a warm day, a water hose, lots of wet sand paper, and several six packs of beer.
For the urethane, --- think I should use a stripper for it? I might try it on a sample part of the body. Might try the metal based sills first.
Old 04-09-2008, 05:24 PM
dbeall1968
dbeall1968's Avatar
I just finished stripping a hood . I started with sandpaper. A thick layer of old laquer paint gummed up any paper in seconds (hand sanding). I tried razor blades, but left a few deep scratches that I am now glassing over. I used a fiberglass stripper from the local auto paint store. It was actually pretty gentle, it never burned my skin, or damaged the glass. It was only effective for about 5 minutes, and required several applications as I went down through the layers. I used a plastic scraper to remove the soft paint. I finally got down to red oxide primer, and I found that Methy-ethyl-ketone took that right off on paper towels. I cleaned it down to bare glass, and began working on small cracks and scratches. I am heading out now to do a little work on it, since the weather is decent. I have a ton of blood red, snotty crap in the bottom of an old trash can now. It looks like a Texas Chainsaw Massacre in there
Old 04-09-2008, 11:10 PM
VetteThunder1
VetteThunder1's Avatar
I used single edge razor blades from Home Depot to remove the top layer of paint but I left the really hard parts so as not to gouge the fiberglass.
I used Citrustrip to strip the paint off from there. I used about 3 1/2 jugs of CS to do the car completely. It was mild and easy to use and cheap too.
After I had the whole car done I took it out and preasure washed it and here is a pic of the result.
As you can see on the right you get really good results. The downside is you have to be PATIENT. I would paint on some CS and wait about 30 mins then paint on some more and then wait another 30 minutes and paint on some more wait another 30 minutes and then start removing the paint. Came off easily.
Here is a pic of the complete car stripped;
Old 04-17-2016, 07:12 PM
jseremba
jseremba's Avatar
Default Citrustrip
Hello
I am stripping the paint from my 1989 Corvette. I bought some citrustrip paint remover. It started to work on the edge where the bumper and rear deck meet. It was 60 degrees and I only had it on for an hour. Does any one have a time vs. temperature curve regarding this stuff. Oh and I was thinking of scratching the paint with some 40 grit sand paper and the applying the Citrustrip.
thank you
Joe
Old 04-18-2016, 10:40 AM
Pop Chevy
Pop Chevy's Avatar
2021 C1 of the Year Finalist - Modified
I like Captain Lee's , best paint stripper I ever used ! Yes it is temp dependent, works better when warm. NOT in direct sunlight, unless you're really quick.
Old 04-19-2016, 01:28 PM
widowmaker221
widowmaker221's Avatar
Has anyone ever tried dustless blasting ? I've seen this on the show My classic car.
Old 04-19-2016, 03:17 PM
530planeman
530planeman's Avatar
I use a baking soda blaster got at Harbor freight but u will need pretty good compressor
compressor
Old 04-19-2016, 08:01 PM
bj1k
bj1k's Avatar
compressor
A friend of mine has two C1 corvettes that we are restoring and he had them soda blasted . It does a great job without all of the nasty mess and you can have it done right in your driveway with hardly any cleanup.
Old 04-22-2016, 04:24 PM
croaker
croaker's Avatar
A fella I was talking with said he saw some plastic blades at some event last year for stripping paint. Maybe do a search
Old 04-22-2016, 05:07 PM
RJ1AZ
RJ1AZ's Avatar
Location: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
Originally posted in 2008?
If he hasn't finished stripping it by now, he's given up.
To Best Fiberglass paint stripper ?
Quick Reply: Best Fiberglass paint stripper ?
