Flasher Probem!!
Flasher Probem!!
I NEED HELP, MY FLASHERS DO NOT BLINK, I CHANGED THE FLASHER FUSE AND STILL NOTHING, WHEN ACTIVATED THE LIGHTS STAY ON, ON THE SIDE TO WHICH THE SWITCH IS TURNED TO. THE HAZZARDS WORK FINE AS WELL AS THE BREAK LIGHTS.
IS THERE ANOTHER FUSE? WHERE?
THANKS DINO
ITS A 75 CONVERT. ALL THE LIGHTS LOOK FINE
THANKS DINO
If the emergency flashers work but the turn signals don't, your problem is the turn signal flasher is bad...located in a clip behind the right-side dash panel (you can reach it; you don't have to remove the panel).
Yep, two separate units. The flasher for the hazards is on the fuse panel, in the top corner. The signal flasher, for some reason, was put on it's own pigtail, clipped up behind the passenger dash knee pad.
Not trying to hi-jack but while we are talking about "FLASHERS" .........
what would cause the flashers to flash slowly or at different speeds left side vs right side ?
Slower or faster than normal usually means you have the wrong bulbs in the lights or there is some corrosion in the sockets/connections which raises the resistance in the circuit.
Thanks To All That Replied!!!!
:Thanks everyone, you were a big help!!!!!
I changed the flasher on the passanger side of my vette and sure enough WHAMMMMM!! the flashers work great.
THANKS DINOX
THANKS DINOX
Could this be a solution to my problem? Remember, when the right turn signal is on, the inside indicator does not flash and the outside all lights up and does not flash except for the tail light which does nothing. The left works just fine though. My hazzards all work fine and flash ( and dash indicators) except for the right tail light, which again does nothing.
Miles
