light replacement.
light replacement.
ok guys, heres a dumb one for ya. I am replacing the tail light bulb. how do I remove it without breaking the bulb? Just have to get it out!
Push in on it , gently, and twist, if it doesnt move spray some bust rust or similar on the base where it contacts the holder. Works for me every time, Good Luck, Peace,,,Moosie
thanks for your help Moos, I saw you were on and hoped you'd chime in, with your infinite Vette knowledge and all. thanks
Update: I replaced the right rear tail light and my problem was not fixed. When I turn on the right turn signal, it doe not blink, just stays on. But when I push the brake the right rear light goes off. Whats the next move?
yes, but I have the same result as I did with the old light bulb in there.
keep in mind that the tail lights work like normal, but it's the right that won't blink with the turn signal( just brightens like the brake is being pushed.) and will not work when the brake is applied(goes off totally).
Well if it lights up but dont blink and goes off when you step on the brakes it should be grounded enough besides the tail lights work properly, is the bulb positioned in the socket the right way ? Maybe you should check the flasher up in the fuse box, other then that unless Bubba's been into the wires what else could be wrong, the switch itself ? Dunno but good luck, electrical problems generally suck. Peace,,,Moosie
no, all of the blinking on the one side doesnt blink, just lights up. Well, if bubba did mess with them he at least got them to work since July of last year. I mean, I was driving down the highway on sunday, and my dad who is following me called and told me that it just started happening. Aggrivated right now!
Check the ground wire that goes into the tail lamp socket on the side. My 78 was acting about the same and the wire was corroded inside the socket. You can test it by running a ground wire to the frame and touching to the brass part of the bulb while it's in the socket and see if it flashes.
Help!!!
***UPDATE***
Alright, we replaced the socket, and the problem is not solved. Now, tail lights stay on like before, the only difference is that the right one does not go off when brake is applied like before. It remains on, but does not get brighter. The blinker also does not blink, all of the right side lights do not blink. Can it be a light is going dead somewhere else in the car? Are there separate fuses for brake and turn signal? Or does it all fall under tail lights? Also, where do the wires run from the fuse box to the tail, is it all under the center console? What else, any suggestions?
Little terminology here: The taillight is the filament that is on when the park/headlights are on - not as bright. The other, brighter, filament is the stop/brake/turnsignal light/flasher light.
What happens when you put the 4-way flasher on? Do all four corners and the two in the speedo/tach flash? When you put the brake on when the flashers are flashing, all lights should stay on - no flashing.
When you turn a turnsignal on, the bright filament should flash. When the turnsignal is on when the brakes are applied, the light should still flash.
Like previous poster said, check your grounds. Check the wiring, and check the flasher itself, altough if the left turnsignals work, it is most likely good. The lamp socket should have two power leads, one for each filament, and a ground. Having a plastic body, Corvettes are notorious for poor grounds, and a poor or missing ground will certainly mess you up. The grounds don't go to the body like on most cars, but to a common point that is grounded on the frame.
Cheers,
Pete
Cheers,
Pete
Alright, the flashers work on the right side and the left side (remember, everything on the left side is fine) , EXCEPT for the right tail light. The front and side lamps all flash. What does this mean? Is the ground to the right tail light bad? When the brake is applied, the right side gets no brighter than the regular tail light. Are we getting close to the answer?
Actually, you try to remove it, bust it in your hand and cut your finger and bleed all over, proceed with the obsenities, then grab a needle nose pliars and pull it out. At, least that is how I did it a couple weeks ago.
I was trying to replace one of my backup bulbs yesterday and couldn't get it out and that was by biggest fear. Even using rubber gloves for better grip, I could only push it and twist it a bit, but not enough to get out. PITA! Have to try again.
The second filament does not light up. The first filament is lit up like normal, but when brake is applied, the second does not light up. When turn signal is on and tail lights are off, the tail lamp never lights up, but the other lights on the right side turn on but don't flash. When lights are on and turn signal is on, the tail lamp remains lit (but gets no brighter.)and the other lights on this side do get brighter, but do not flash. On both of these, the dash indicator stays lit and does not flash. Here's the tricky part, when the hazard lights are on, the dash indicator flashes and the whole car's exterior lights flash EXCEPT for the right tail lamp. What gives?
Since it is a new bulb and a new socket, does one of the three wires running into the socket only control that second filament? I assume one is a ground. What do you think? could one of the wires be bad that runs to the new wire of the new socket?
