Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
New! Use your Facebook to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-03-2008, 10:54 AM   #1
foooz
CF Senior Member
Default Vacuum Line Kits
I am planning to replace all the vacuum lines on my 75 w/ac. I see there are kits available at Ecklers. Has anyone tried one of these (or other vendor) kits? Do all the plastic fitting come with the kit as well?
scott
foooz is offline   Reply With Quote
Old 03-03-2008, 11:25 AM   #2
PETKAH
CF Senior Member
Look at Dr Rebuild's site on the web - he has diagrams/details of what's
in each kit. and instructions. Note that there are kits for engine compartment, then under dash/etc. Just a thought - only replace one line at a time so you make sure to get right connection. The engine compartment looks really clean/detailed when they are installed.
PS- pay $4 for the Dr Rebuild catalog - it's a great reference for all types of parts.
PETKAH is offline   Reply With Quote
Old 03-03-2008, 11:38 AM   #3
bene
Junior Member
Support Corvetteforum!
I used Doc's Rebuild kit on my 71. Everything fit perfectly. They were quality and color coded along with the diagrams.
bene is offline   Reply With Quote
Old 03-03-2008, 12:19 PM   #4
A72COUPEDT
CF Senior Member
A72COUPEDT's Avatar
Default The Doc's the way to go....
Go see the Doctor...he's got it right!
The advice on the catalog is another good
idea.
GOOD LUCK!
A72COUPEDT is offline   Reply With Quote
Old 03-03-2008, 01:06 PM   #5
markdtn
CF Senior Member
markdtn's Avatar
Quote:
Everything I needed was there.
markdtn is offline   Reply With Quote
Old 03-03-2008, 01:41 PM   #6
stingr69
CF Senior Member
stingr69's Avatar
Quote:
scott
I bought some kits from the Doc and they are very good. I do not think he has them with the integral moulded ends. I think you will get a bag of loose individual color coded lines and a routing diagram with them.
-Mark.
stingr69 is offline   Reply With Quote
Old 03-03-2008, 02:36 PM   #7
stock76
CF Senior Member
Got mine from Doc Rebuild too. Had the original GM color coded stripes on the vacuum lines, and all necessary replacement tees and elbows, etc.
stock76 is offline   Reply With Quote
Old 03-03-2008, 10:26 PM   #8
Sayfoo
CF Senior Member
I bought a kit from Zip about 5 yrs ago. The best I can say is that it is a functional replacement. The hoses are a larger outside diameter than the origional hoses. Not NCRS quality for sure. Also, their routing diagram showed a incorrect connection at the head light switch. This had evidently been known for a number of years, but was not changed till about a year ago. This caused me a lot of grief, because the system did mostly work, but not really correctly. When this was discussed on the forum about a year ago, Zip appoliged and promised to update their drawings. Sounds like the Dr has a good kit.
Sayfoo is offline   Reply With Quote
Old 03-04-2008, 10:35 AM   #9
yel76low
CF Senior Member
yel76low's Avatar
So speaking of Doc. Rebuild's kits... where does the small port of the 'B' tee go to? I'm in the middle of changing my vacuum lines, and the lines that are on my car are massively screwed up... as in not even close to what they should have been.
yel76low is offline   Reply With Quote
Reload this Page Vacuum Line Kits
Tags
75, ac, c3, c4, c5, corvette, diagram, line, lines, vacum, vacume, vacuum
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Vacuum Hoses Dk Met Grn 80 L82 C3 Tech/Performance 10 04-21-2003 09:55 PM
New to corvettes. Just bought a 1971 covertible John D. C3 Tech/Performance 24 07-03-2002 12:40 AM
Vacuum advance and low RPM performance 101 clearrun C1 & C2 Corvettes 27 06-29-2002 08:57 PM
Where's a good place to find vacuum hose kits? joeveto C3 Tech/Performance 10 04-16-2002 12:02 AM
Vacuum relays daniel77350 C3 Tech/Performance 11 09-15-2001 01:28 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive -
Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
