Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-10-2008, 11:51 PM   #1
bigpoppamikebb
Junior Member
Default engine firing order
can anyone give me the firing order for a stock 77. is there a diagram ? what are the best plug and wires for this model ??
bigpoppamikebb is offline   Reply With Quote
Old 01-11-2008, 12:07 AM   #2
greyghost79
CF Senior Member
1 8 4 3 6 5 7 2. same as all chevy 350's.
greyghost79 is offline   Reply With Quote
Old 01-11-2008, 12:44 AM   #3
Carl Granquist
CF Senior Member
Support Corvetteforum!
Carl Granquist's Avatar
The A.I.M. (assembly instruction manual) is great for stuff like this. Yes, it has a diagram. Easy to see all the engine compartment wires. Dizzy rotates clockwise as you look down on it. Driver's side, front to back, 1-3-5-7. Passenger's side, front to back, 2-4-6-8. Now follow with the 1 8 4 3 6 5 7 2 sequence.
Without you filling out your profile, it's a little harder for us to help with information. Are you using other-than-stock spark plugs? Several manufacturers of wires (e.g. Jacobs, Delco, etc.). What kind of driving style? There's a lot of folks here with tons of experience.
Carl Granquist is offline   Reply With Quote
Old 01-11-2008, 08:18 AM   #4
Trae1976
CF Senior Member
Trae1976's Avatar
Click the image to open in full size.
Trae1976 is offline   Reply With Quote
Old 01-11-2008, 09:28 AM   #5
markdtn
CF Senior Member
markdtn's Avatar
I would buy stock Delco wires and plugs. You can get Delco wires at Advance and O'Rieleys. I have also had good luck with Moroso Blue Max wires.
markdtn is offline   Reply With Quote
Old 01-11-2008, 10:02 AM   #6
rayluka
CF Senior Member
rayluka's Avatar
Quote:
I used this exact diagram and found all my wires needed to be clocked back one spot counterclockwise on the distributor. I couldnt get it to run. My friend who is a mechanic on the pier in Long Beach saw it immediately. Maybe its my setup as the firing order is the same but #1started at the # 2 spot and so on. If it works for you dont let me confuse you, but if you run into a problem you may want to look at this as an option.
rayluka is offline   Reply With Quote
Old 01-11-2008, 10:26 AM   #7
Merlinhaggard
CF Senior Member
Merlinhaggard's Avatar
Either the dist is off a tooth or the rotor needs to be 180'd.. Im sure you started at TDC on #1..
Merlinhaggard is offline   Reply With Quote
Old 01-11-2008, 10:52 AM   #8
halfmoontrail
CF Senior Member
halfmoontrail's Avatar
Quote:
It makes no difference where the wires are on the distributor cap, as long as the firing order and direction are right, and if #1 sparks near TDC on its compression stroke.
Steve
PS: Plugs are plugs, wires are wires, save money.
halfmoontrail is offline   Reply With Quote
Old 01-11-2008, 11:45 AM   #9
Vettebuyer5869
Moderator
Vettebuyer5869's Avatar
Location: About 1100 miles from home. (The World Champs)
Why do they bother with a tech section on this forum? Seems pointless.
Vettebuyer5869 is offline   Reply With Quote
Old 01-11-2008, 12:50 PM   #10
Trae1976
CF Senior Member
Trae1976's Avatar
at myself, don't know why I didn't spot that. That's not my diagram, just one I found on another website to help out the OP. You are correct, that doesn't match the stock configuration. Sorry for the confustion. :o
This one is correct, just not as "clear":
Old 01-11-2008, 03:38 PM   #11
Thmprr
CF Senior Member
Thmprr's Avatar
Actually, the position of #1 on the distributor to the pass. side stems back to 1955, if you check the maintenance manual that's where it's put. The later way suits the HEI style better.
BTW did you know that you can now get HEI caps which are phased correct for cylinder position and firing order.
Thmprr is offline   Reply With Quote
Old 01-11-2008, 05:19 PM   #12
halfmoontrail
CF Senior Member
The first drawing is more clear to me, but it really doesn't matter...put #1 wherever it falls on the cap, and then follow it around according to the firing order.
You can drop the distributor in anywhere, and still end up with proper wire routing, usually the vac advance can is the limiting factor.
Steve
Old 01-11-2008, 06:15 PM   #13
Merlinhaggard
CF Senior Member
Quote:
You should start your own website. See if you can get all of the other negative people to go with you..
Otherwise thanks for your input on this subject..
Old 01-11-2008, 06:32 PM   #14
bigpoppamikebb
Junior Member
thank you all for the great help. I will get started on this tonite about 10pm after I get off work.
Old 01-11-2008, 06:53 PM   #15
427basketcase
CF Senior Member
427basketcase's Avatar
Hey, just for grins here...what about the 4/7 cam
427basketcase is offline   Reply With Quote
Old 01-11-2008, 11:38 PM   #16
33Chevy
CF Senior Member
33Chevy's Avatar
427basketcase
I was thinking the same thing...OEM SBC is: 1 8 4 3 6 5 7 2 (as mentioned).
If someone installed a 4/7 cam conversion it would be: 1-8-7-3-6-5-4-2
I did grin...but it is something to be aware of when trouble shooting.
(They say switching the firing order of 4 and 7 is worth 5 to 30 HP?, but you need the 4/7 cam installed)
33Chevy is offline   Reply With Quote
Old 01-12-2008, 10:57 AM   #17
dannyman
CF Senior Member
dannyman's Avatar
Good picture!!
You can remember the installation without a picture.
Note; looking down on the top of the distributor cap, how the distributor wire connection for number 1 cylinder is the closest connection and in-line with number 1 cylinder. This is the best position for the cap to allow for distributor timing (most uninterrupted cap movement at this position).
Firing order is written on the intake manifold, (raised numbers manufactured on the intake)
dannyman is offline   Reply With Quote
Old 01-12-2008, 12:00 PM   #18
1972corvette454
CF Senior Member
1972corvette454's Avatar
Default Is it the same for the BB 454
1972corvette454 is offline   Reply With Quote
Old 01-12-2008, 12:19 PM   #19
moosie982
CF Senior Member
moosie982's Avatar
Send a message via AIM to moosie982 Send a message via Yahoo to moosie982
Peace,,,Moosie
__________________
'80 L-82, Presently in the process of taking the '80 apart cause it's a rust bucket, And putting the drivetrain and interior into an 82 that I bought. With a changeover to a 4 speed while I'm at it. Other interests My son and daughter. Our '40 Ford Deluxe tudor sedan (stock for now) and our favorite,,,, ole Blackie, our '78 Harley Davidson Low Rider (FXS), the "REAL" freedom machine!
Ever wonder what the speed of lightning would be if it didn't
zigzag?
moosie982 is offline   Reply With Quote
Old 01-13-2008, 08:16 AM   #20
dmaaero
CF Senior Member
dmaaero's Avatar
I rembember reading on a points dist. the #1 postition points towards the #2 cylinder, on a hei dist. the #1 postition points towards the #1 cylinder.
dmaaero is offline   Reply With Quote
Reload this Page engine firing order
Tags
bigpoppamikebbyahoocom, c3, corvette, engine, firing, order
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
NEED HELP! Firing order when distributor is 180* out? CrossedFlags77 C3 Tech/Performance 25 02-15-2005 01:33 PM
Help setting firing order VetteMan55 C1 & C2 Corvettes 15 12-24-2004 02:12 PM
Anybody tried the new 4 & 7 swap cam from Comp? Jussi Engine Mods 11 09-04-2004 10:45 AM
86L-98 Firing order? CLUTCH^Master C4 Tech/Performance 30 04-01-2003 09:57 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
