71 Lt1 Info Need Help
i just bought a 71 coupe lt1 with 68k original miles this car is all original and has been in storage for 25years or so.it has never been hit or had any paint work done.my question is did all lt1 cars come with the big block style hood?this car has a standard hood and the fellow i bought it from said it had always been that way. help out there?.
Neuman!
I've been looking high and low for your new car! Yes it has the big block hood, but no holes where the "454" would be, just a decal. Post some pics and your price to sell it to me.
Greg
Greg
i have a few pics of when i bought it not very good as the car was stuffed i a garage but i will post them.this car doesnt have a big block hood and i look and looked and it doesnt appear to have ever been changed.could one car have slipped threw the cracks and got a reg hood?could it have been ordered that way?i
The LT1 intake carb and air filter will not fit under the flat hood. I'll bet the car is not an LT1. Do you have any documentation? There are a few tell tale signs of an LT1 but the hood is obvious. No it did not slip out the back door this way.
engine code is cgz
options are
A85
Custom Shoulder Belts
C50
Rear Window Defroster
J50
Power Brakes
LT1
350ci 330hp Engine
M21
4 Speed Manual Close Ratio
N40
Power Steering
A31
Power Windows
PU9
White Letter Tires F70x15
PO2
Deluxe Wheel Cover
U69
AM/FM Radio
options are
A85
C50
J50
Power Brakes
LT1
350ci 330hp Engine
M21
N40
Power Steering
A31
Power Windows
PU9
PO2
Deluxe Wheel Cover
U69
AM/FM Radio
i will send you some tommorow,have to take them tonight when i get home.the hood is a little hard to open and doesnt fit well as you can see in the one picture.may be it was changed some time ago.it does have the correct intake and carb,valve cover etc on it.i did run all the numbers i could find on the motor etc and everything seems to me right.hood closes fine but it is tight and looks like it might hit the air cleaner housing.anyways i didnt want to spark any great debate on if the car was a real lt1 or not.i know it is, i just wanted to know if anyone ever had seen a lt1 with a reg hood on it.
Received 2,878 Likes
There has been a debate (war) for years about 67 small blocks with big block hoods. Wouldn't it be great if this was the start of a LT-1 debate.
Regards,
Alan
Regards,
Alan
Not the same thing
Also , most of the list of optons does not indicate LT-1 , the radio proves nothing.
The CGZ is LT-1 , but is that original?
Nothing in the VIN tells anything
The tach face can be replaced with a 6,500 face.
I suggest you pull the oil pan and see if it is a 4 bolt main.
Also the emission sticker behind the brake booster should have AX
Check right side wall of fuel tank , reach hand up and feel for concave portion , is there a nipple ? If so that is a base car tank , If no nipple then that is a LT-1 / LS6 tank
Are there heavy duty caps on the rearend side yokes?
With a M21 rear end ratio should be 3:55 / 3:70 / 4:11
car would tach no less than ~2,650 @ 60 mph with 225/70 tires
look at the driver side front fender well by opening the hood , there should be T.I. ingition amplifer or if it was removed then the 3 bolt holes should be there. 2 holes low and 1 hole at top.
David
I love these LT1 cars. The 4 I've had were in 70 Z/28's and were a blast to drive. I think the Z/28 had a weight advanage also. I'll be set right if I'm wrong, that's for sure.
I love these LT1 cars. The 4 I've had were in 70 Z/28's and were a blast to drive. I think the Z/28 had a weight advanage also. I'll be set right if I'm wrong, that's for sure. I really think the HP was the same. Gm did the old decal mombo jumbo. Even if there was to 10 hp diff wouldn't notice the diff.Now torque that might be a different story. I can't remember who had what but with this Al Gore invented internet it shouldn't be to hard to find.Which just reminded me to buy some more carbon offsets.
you guys amaze me you are so quick to say the car isnt a real lt1,i dont have a concern it being a real lt1 car i have all the documentation as well like i said in the one post that the sheet is still on the tank.i just was asking about the hood.i have a few vettes now and have owned 50 or so in my day and i have seen alot of different things on original cars.
like the great debate with big block hoods on small block c2,s i have had a few if those as well.as for the hood not closing it does as you can plainly see.i am sorry for asking the question i really didnt think the car authenticity would be questioned.
i have a 70 coupe 350 350h.p. car in the same condition with a big block hood.again a number matching unrestored car with 35k miles.now are you going to tell me the it isnt a original small block car because it has a big block hood.
Unless you are the origional owner its hard to say what has been done to the car by previous caretakers. All the documentation in the world doesnt really amount to much unless you are the first, origional, owner . It is 2007, soon to be 2008 and we are talking about a car that is 36/37 years old. I dont doubt the car is what you say it is, and that is fine with me and is I am sure with a great percentage of the guys here. Peace,,,Moosie
At one time... I put a 3/4 inch ball of plumbers puddy on my 72 LT-1 air cleaner...and eased the hood down on it. My original hood has between 1/4 & 3/8 inch clearance over the cleaner. Needless to say, I would imagine this clearance shrinks with a little torque on the engine Muddy
CI 5 & 8 Veteran
With regard to your hood, I would bet my stable of vettes that that stock SB hood is not original. The odds of that level of substitution (at least in 70-72) are zero. That's not to say that a dealer couldn't have replaced it after the fact, but why?????
So, you have a SB 350/350 with the BB/LT-1 hood??? Why don't you just switch them and be done with it? The cars will be worth more in the long run.
Bullshark
1974Pantera (07-04-2020)
