Oil pressuer fitting on block leaking, how to best fix?
Do I need to replace the entire line to the guage?
Or can it be fixed at just the threaded connector?
2nd question: I noticed some oil leaking from the left 2nd front intake manifold bolt and the right rear bolt. Can I just loosen the bolts a bit & seal up with RTV silicon and re-torque? Whats best?
Thanks in advance.
Glenn
Thanks in advance.
Glenn
From working on Vettes, you most likely have to pull the engine just to access what is wrong!!!
Is it a BB or a SB? The oil line has a crush fitting on it, maybe tighten or replace it (the crush part). GOOD LUCK>>>>........
1 Post
Thanks in advance.
Glenn
Thanks in advance.
Glenn
I had a similar problem with bolts leaking onto my intake. I used vibra-tight on the threads of the bolts. No leaks so far.
Good luck,
Dino
Just for that! It's a small block. The fitting is right behind the intake manifold and easy to reach.
Thanks in advance.
Glenn
Thanks in advance.
Glenn
The plastic oil line on my SB using a compression fitting. If you have enough slack in the line, you may be able to snip off the end and replace with a new compression fitting. The oil line kits are that expensive, about $10.00 or so.
Good luck,
Dino
Good luck,
Dino
Thanks.
Glenn
St. Jude Donor '11-'12-'13,'19-'20
BE careful with the OP line. If it's plastic and been on the car a long time, it's most likely brittle and may crumble in your hand. Mine did!. Then your pulling the center dash to run a new one. If it's only a drip, I would gently try and simply tighten it without removing it first. If it's copper and you have slack, no issue except to make sure you use a pipe cutter.
If my intake bolts were leaking like that I would pull the intake and replace the gasket.
Some hate it....but I replaced mine with copper to "just before" it enters the firewall. Nylon continues to the gauge. Be sure to put a few neatly done loops in the copper for vibration.
Glenn
Thanks for the pic.
Glenn
Glenn...not positive what its called, but NAPA ....some O'Reillys sell a copper kit with an assortment of fittings to do the plumbing. Its about 12 or 15 bucks and comes with the copper tubing. Just use an "assortment" of sockets as a guide in putting the curves in the tubing.
Thanks again, Glenn
Use the Loctitie or RTV
The bolt threads are exposed to oil internally and it wicks up the threads. The gasket won't do anything for that.
I had this same problem with the intake manifold bolts: oil wicking up the threads. Easy fix. Removed and cleaned the leaking intake bolts. Applied thread sealer. No problem in 3 years.
After reading this thread I checked my oil pressure line and fitting at the rear of the intake manifold--and it is leaking! Apparently it just started. Will attempt to carefully tighten it, but it appears to be leaking at the point where the plastic line enters into the top of the fitting on the intake manifold.
Thanks, Glenn
Several years ago I flew to Tulsa to look at a red 72. Looked good and I bought it. It showed about 35 on the oil pressure gauge. A week later I flew BACK to Tulsa to actually "do the deal" and drive it back to N. Ga. Upon starting it up....ZERO oil pressure. The seller said...Yea, sometimes it does that, I think the WIRE is loose or maybe it's just the fuse....you will be fine to get back to Georgia.
I said ...Sir...you have no idea how this car actually works, do you? He had accidently broken the nylon line while putting the chrome ignition cover back on during the week. I re-installed the oil line (in his driveway) before leaving Tulsa and made it home just fine. In a few weeks I replaced the old brittle line with the copper you see in the picture above.
Glenn,
I won't have time til next week to look at my leaking oil pressure fitting on my intake manifold, but if our plastic line to the gauge is not broken---and we do not break the line during the repair process---I think we can remove the brass fitting on the intake, put sealer on both threads, and then reinstall. I am going to first attempt to simply retighten before doing any removal.
If anyone else has any tips, let Glenn and I know!
