Rookie's first attempt at a restoration...
Old 10-06-2009, 05:40 PM
  #1001
BenUK
BenUK's Avatar
Originally Posted by stinger12
Dude, we still need to talk on the phone!!! I totally forgot about that...woops.
It's no problem - my plans have changed since I contacted you. I thought I could try and fit the floorpans myself but I realised that I lack both the skill and patience to do a good job so someone else has been with me for the last couple of days helping out. It's going well. Your freshly-blasted metalwork has been a useful reference point though, so thanks again.
Old 10-09-2009, 10:30 PM
  #1002
stinger12
stinger12's Avatar
Finished bonding the floor pan to the bottom of the rear tub. This job was very tedious, and required a ton of prep...I never want to do this again! Ever tried fiberglassing upside down Tomorrow I will drill the holes out for the new rivets, and pop them in. Then I will be done with it.
Next project is the #4 body mounts (fiberglassing) and installing the cover reinforcements on them. I'm extremly close to finishing the underbody - less than a month before I get to install the body!
Old 10-10-2009, 03:16 AM
  #1003
stinger12
stinger12's Avatar
I can't decide whether or not I should undercoat my underbody. I'll definitely undercoat just above the tires to prevent spider cracks. The bottom of the vette is spotless now - not one spot is uncleaned. You could eat off of it. I want to keep it that way.
Suggestions on a paint color to go with (if I decide to paint it)?
Old 10-10-2009, 10:23 AM
  #1004
avner
avner's Avatar
I just paint the underbody & the wheels house after I clean up with silk black paint but will spry some pitch like (I don't no the name for this black staff in English) on the wheels house after I install all the reinforcement brackets that I took out from the body to restore/galvanize them.
Avner
Old 10-10-2009, 05:24 PM
  #1005
earthquake68
earthquake68's Avatar
Back in the day, when we wanted a painted surface to be durable, we shot it in Dupont Imron. It's a sprayed paint, but is just short of powder coating in terms of strength. I'm not even sure you can still buy it. The stuff is toxic as hell.
Old 10-14-2009, 09:07 PM
  #1006
stinger12
stinger12's Avatar
I finished the floor pan to rear tub bonding/rivetting. I countersunk the screws holes (the ones which were used as clamps during bonding) and packed them full of marinetex and sanded them smooth. Everything is getting a coat of undercoating once finished. If this were the outside of the body, then I would have glassed those holes shut...but this is the underbody. This bonding adhesive is insanely strong...I still can't believe how good the stuff is.
Next I finished sandblasting the pillars (the areas getting covered by the access covers). I masked them off, and gave them a coat of krylon rust tough enamel. Just these two areas are getting spray painted - the rest of the car is getting sprayed with my new paint gun and some high end primer.
Then I started to prep some cracks for fiberglass repairs. I also masked off the inside of the #4 mount, and applied bondo on the backside...a trick that works awesome!
I still have a ton of work to do before I get to reunite the body/frame. Once again, I am beat/extremely exhausted.
Old 10-15-2009, 12:38 PM
  #1007
stinger12
stinger12's Avatar
These pieces were still in good shape (seatbelt reinforcements). Water usually collects behind them and then they rust out. I sandblasted both sides (looks a little funny...there is still some original plating on them, which is some pretty tough stuff), then applied a ton of bonding adhesive on the backside. I pressed it tight against the fiberglass until it oozed out and sealed it to the tub. No water will be able to get to it now. I sandblasted the fiberglass before I bonded the reinforcements in place.
Old 10-18-2009, 07:38 PM
  #1008
stinger12
stinger12's Avatar
I finally found my second pair of US Indys on Ebay the other day! I bought them last night - now I need to polish them
Old 10-19-2009, 05:35 AM
  #1009
stinger12
stinger12's Avatar
I sandblasted these two areas on each B-pillar. This is where the access cover butts up against, and GM never bonded them there. I am going overkill on everything - I never want to do this again.
Next I prepped one of the access panels for fiberglass repairs. I stripped the panel of all the crap and crud last night.
Here is the repair...
And here is the left #4 mount all glassed up...
This area needed some glass work as well. It was previously repaired by GM using a 1/2''X1'' piece of fiberglass cloth...
I sandblasted and powdercoated these two covers for the access covers in front of the rear tire...
Time to get some sleep
Old 10-19-2009, 01:29 PM
  #1010
Aggitated Monkey
Aggitated Monkey's Avatar
I realy like the additional prep in this car. It will weather time better than origional.
Old 10-19-2009, 02:34 PM
  #1011
stinger12
stinger12's Avatar
Lets just hope I don't run out of gas before I reach the final destination...its starting to wear me out physically and mentally. Gotta keep push'n myself!
Old 10-20-2009, 06:31 AM
  #1012
rtpilot
rtpilot's Avatar
Greaaatt job. I restored a Piper Cub when I was your age. Took two years. No rush. When I got tired, I took off some time. It was always there when I got back to it. You only get to do this once. Why not enjoy the pleasure of your work. BTW I flew that plane from Philly to LA and back. (45 years ago).
Old 10-20-2009, 07:44 AM
  #1013
1996Z15
1996Z15's Avatar
Keep plugging away but, don't make it a chore. Like the previous poster stated, this should be enjoyable and something that you'll be able to take great pride in once you're done. It looks like you're close to starting the reassembly process where you'll really start to see a car emerge from all of the parts you've been working on and assembling.
We all enjoy seeing your updates and I know I am envious of your abilities; I'd love to have the ***** to tackle doing something like this to my '69 coupe.
Old 10-20-2009, 07:20 PM
  #1014
Thmprr
Thmprr's Avatar
When I find that it's not fun anymore during my restoration of my 57 2dr Sport Coupe, I take a few nights off, then recharged, I'm fine for a while. I liken it to eating an elephant a bite at a time! I have 3000 man hrs into it so far, and looks like anothe 200 to go.
Old 10-20-2009, 07:28 PM
  #1015
stinger12
stinger12's Avatar
I'll take a break once the body is on...that's when all the fun stuff will start. No more cleaning or scrubbing panels...everything is already stripped. I am pushing myself really hard to get the body back on the frame in under three weeks from now...I could not be working any harder at the moment (there is no possible way...especially with my full time job).
Old 10-20-2009, 08:31 PM
  #1016
vagabond407
vagabond407's Avatar
Heck yes!!!! Everyone has already said it, but I'll say it once more.
Amazing work...can't wait to see it progress. I've been on mine hard the last two months or so. On top of working 70-80 hours a week...still do a couple hours each day and 8-14 hours on my one day off. I can totally understand the exhausted part.
A bigggg pat on the back from me!!!
Mark
Old 10-20-2009, 11:56 PM
  #1017
Aggitated Monkey
Once you complete the body assembly you will see the progress move much faster. Stay with it and not too far down the path you will reach the bolt together stage.
To Rookie's first attempt at a restoration...
Old 10-21-2009, 02:33 AM
  #1018
stinger12
stinger12's Avatar
Woohoo... I'm almost done the left #4 mount!
Ever tried to prep the inside of a #4 mount for fiberglass...talk about a tight fit
Old 10-21-2009, 02:36 AM
  #1019
stinger12
stinger12's Avatar
Yeah, imagine that. I can't believe how much energy this thing sucks outa me. I have a ton, and I mean a ton, of respect for the guys doing this for a living.
Old 10-22-2009, 10:53 AM
  #1020
stinger12
stinger12's Avatar
The #4 mounts are almost done...I just need to glass the outside of the passenger one.
Quick Reply: Rookie's first attempt at a restoration...
