Help decode engine cylinder head numbers
I'm trying to decode my numbers on my 327 cylinder heads. There are two different casting numbers which seem strange to me.
3917281 G58
3917291 G68
I was able to find 3917291 but unabale to find information on the other. I have a 68. Thanks in advance
3917281 G58
3917291 G68
Check this out http://www.nastyz28.com/sbchevy/sblock.html
Edit : Oops, I gave the wrong link, should have given : http://www.mortec.com/
3917281 Double hump head: I have one of these too. It is the right head on my 327-300 68 Corvette. The motor is around a July 68 build. My left head is 3917291. The later number is listed but like you I haven't found documentation on the first head number. Contrary to a comment you got about misreading the number, these are casting numbers and the right and left are different casting numbers as they come from different castings, ie -the left and right are not the same. I would be interested in hearing from you concerning this to see if you know anything more about this casting number. Thanks. Larry - 68mako2
Received 1,469 Likes
Cruise-In II Veteran
