Show off your engine bay
#154
Not much to look at yet, but it is a pretty clean original to start with. I have the original air cleaner and distributor cover that I want to put back on.
#155
You are correct!
I bought the Summit Billet Alt, and Pwr Str pump brackets and they changed all my belt sizes.
I will actually have to mod them and use the first 2 grooves on the crank pulley to run my belts. It will look cleaner when done, I will post pictures.
If you look you will also notice I have only one new Edelbrock short valve cover which will not work with the Roller Rockers I bought.
I have no fuel line, carb, rad hoses, vac lines, heater core box, distributor, MSD (optional but I need it), exhaust man, radiator, fan....
Oh my God I still have a lot of money to spend!
I hope to finish before summer is over, but I love this Thread so much I thought I would show my work in progress.
Thanks Durango, I think you are an asset to the site, and I often read your posts.
#156
Mine definately isn't the nicest out there, but I'm proud of it none the less!! It tooke me two years of work and lots of money, but I replaced my L-48 with a 465 hp, 450 tq 383 complete with Trickflow aluminum heads, Holley 4150 Carb, MSD digital E-curve distributor, etc.
I painted the entire engine compartment with krylon semi-gloss black and I couldn't be happier with the way it looks.
Before:
After:
Before:
After:
#158
Seriously, I actually found an Amway/Quickstar link where they are using this.
http://images.google.ca/imgres?imgur...3DO7U%26sa%3DX
