Tools
Tools
What tools/equipment in your garage have earned thier value for you.
Kwiklift
Air Compressor
Bead Blast Cabinet--Worth it weight in gold
Gonna admit floor jacks and jack stands...those are givens
You?
Kwiklift
Air Compressor
You?
I gotta give props to the floor jack that I bought over 25 years ago that I still use all the time. It's a Craftsman and cost me something like 25 bucks back then.
Air compressor no doubt, it makes the impacts, air rachets, paint guns and air jack and a bunch of other stuff all work.
12ton press was a nice addition
Dewalt grinder with brush wheel
Bead Blast cabinet
Looking forward to seeing what I can do with the new MIG welder
Bead Blast cabinet
1300lb over head electric hoist. Paid for itself already, vs renting. Twin head halogen lights. Battery charger/starter. Vise. Damnit tool (used it more than I care to remember)
Impact wrenches. Twisting on a single rusted in bolt with a ratchet for about 5 minutes is probably why I gave up working on cars for about 40 years. Took all the fun out of it.
My 60 gallon 5 hp Ingersoll Rand air compressor that I got on clearance for $250 as damaged because someone didn't realize that a 240 volt motor doesn't work on 110 volts.
Also my Snap On MTG2500 scanner. It paid for itself in the first year I had it. $45.00 everytime I plug it into someones car.
Kwiklift****Gives good working height. You can lean against it while working. Started to remove rear suspension on my 80 today. Had to sawzall bolts on flange of catalytic converter, made it very easy.
1-Makita cordless drill,use it everyday for something..
2-Makita 4" grinder or cut off wheel..
3-Gear Wrench sets....
4-Electric impact..
5-Fluke multi-meter..
6-The rest of my hand tools in their roll around...
4-Electric impact..
Tools that are Well Used:
20 Ton Hydraulic Press
Oxy-Aceteylene Torch
HD Bench Vise
Made in USA 3/4 HP Craftsman Bench Grinder (Wire Wheel)
Pencil Grinder - Cut Off Wheel
The press is surprisingly useful.....
HD Bench Vise
tourque wrench.
one of those cheapie ,pen type ,electric,"is it hot" tools.
cheapie, magnetic ,pick up tool
jack stands (safety)
electric volt/amp meter
a long roach clip type ,surgons plyers
a set of dental probe type picks
a tool box that actually holds almost all my tools( home made)
square and torx type screwdrivers
a cut in half piston from my old ford pick up (6 banger)acting as an ashtray.
a radio in the garage.
