Thanks for the pics guys. I found what I was looking for. I am running a mechanical fuel pump with a rubber hose to connect to the fuel log. What I need is a part number and where to buy the fitting that connects to the fuel log for a rubber fuel line to push on.
Thanks again for all the information, this site (ROCKS !)
Hey Bob, looks like you have a tvmade ez kit on that. What parts did you use to hook it and your accelerator cable up with?
Thanks,
Michael
all the parts came from BTO...i let other people do my engineering on this one....and i did not install the trans pan until it was all hooked up so i could visually see the WOT activating that plunger rod properly and then i measured the distance from the back of the bracket how far the TV cable adjuster was showing so if any one ever hit it accidentally i could set it back to the proper setting...which i had to do when one one of my friends was touching crap in my engine....
