Ford Expedition Fuse Panel
Originally Posted by SmokinBBC
Anybody out there know where the fuse box is located in a 2003 a Ford Expedition?
pop open the hood, and look to the drivers side. i believe that is where it is on my explorer. may be the same for you.
take the lower dash panel loose under the steering column, 2 screws at the bottom. it may have a black cover on it but it it is right there. there is also one under the hood. what type of problem are you having? I am a Ford tech (my real job) I can help you out.
Paul
Found it
Gator, I found it...It is behind the kick panel on the passenger side.
There appears to be only 1 fuse box with a whole sheetload of fuses.
There is a master panel on the engine firewall on the passneger side. There are 3 large harnesses that plug into this panel.
I followed the first harness accross to the other side of the engine and through the drivers firewall. On the inside of the car it goes down under the sill plate to the rear of the vehicle...must be for all the rear electronics? Is there possibly a fuse panel in the back?
I couldn't follow the second harness.
The third harness goes strait down the firewall into the pasenger area behind the kick panel and into the fuse box.
Now, to figure out which fuse it might be. The owners manual is not clear on where the fuse box is. But it does have a good listing of the fuses.
BTW, this is a full loaded Eddie Bower version with all the toys including the 2/4a/4h/4l gear box....it is a fantastic vehicle for my family of 5, boat, trailer, etc. (Boat is a 26ft cruiser weighing in at about 8000lbs with trailer dry..the expedition handles it no problem with the proper load adjusting hitch)!
Thx for the help.
Thx for the help.
Thx for the help.
Thx for the help.
I will pm you my cell number
I think I found it..
Location number 39 front console power point, rear console power point.
Looks like both go through the same fuse.
thanks
Paul
thanks
Paul
