Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-08-2006, 12:27 AM   #1
vetterbetter
Junior Member
Default Front Clip
I want to remove my front clip, but I'm not sure how to approach it. Do you heat up the glue and use a putty knife? Is it hard to reglue back onto the car after restoring it...alignment wise? The part of the firewall which glues to the fender seems to be cracked, still being partially glued to it though. I mean, I want to do the restoration of my '76 the right way, not the fast way. Can somebody who has attempted to remove/reglue their front clip please respond to this post, I really need help. How did you approach it? Did you do it while the body was on the chassis, or while it was of the chassis? Do you have pictures of how it is glued to the firewall? Is it worth removing the front clip?
vetterbetter is offline   Reply With Quote
Old 10-08-2006, 02:13 AM   #2
johns_vette
CF Senior Member
johns_vette's Avatar
Default not unless you must
I have done this a few times, both removed and installed front clips. Is it worth it? If it's not necessary, don't. Yes, it's alot of work and re-aligning can be a pain. Typically, you will do more damage removing the clip than fixing the problems at hand. Sounds like you just need to clean up the area that has become unbonded with 40 grit and rebond. The best advise I can give it read/search this forum, read books and look at the pictures relating to corvette body panels and bonding areas.
John
Quote:
johns_vette is offline   Reply With Quote
Old 10-08-2006, 08:13 AM   #3
RPOZ4Z
CF Senior Member
Cruise-In VII Veteran
RPOZ4Z's Avatar
I used a heat gun with some nice sharp wood chisels. it came right off.
Click the image to open in full size.
RPOZ4Z is offline   Reply With Quote
Old 10-18-2006, 05:11 AM   #4
Coldburn
CF Senior Member
Send a message via Yahoo to Coldburn
Default Windshield Frame <- Bang! It's DEAD!
With rust all around the windshield frame, I guess I'm going to have to join the club! I'd like to tackle the chassis frame anyway, it's suspect...
What year is the car in the pics? It looks like it was bonded to the top of the firewall too, along with the sides close to the doors?
I think you said you did use a heat gun, if so... did you use it on the outside of the panels (painted side) or just the inside or both sides? I have no paint so that doesnt matter to me but dont want to ruin anything!
When using the chisel, I assume you start from the bottom-up?
I wouldn't imagine the front-clip being very rigid as you remove it from the cage and you can lightly pull the fender away from the body as you chisel?
Thanks!
Coldburn is offline   Reply With Quote
Old 10-18-2006, 10:25 AM   #5
NHvette
CF Senior Member
NHvette's Avatar
Thanks!
Installing the front clip was the most nerve-wracking part of my resto.
Don't do it unless you have to.
Windshield frame rot at the corners can be uncovered by cutting
the corner of the fender off with a hacksaw. Reglassing these back
in will be nothing compared to the clip.
Stress cracks at the edge of the fender should be ground out in a
shallow V and reglassed with matte/resin.
All that said ... yes - chisels and heat work well. I did mine before
learning to use a heat gun, too. The top of the firewall has a thin
strip bonded across the top. I chiselled this apart, but later learned
taht most people will cut the thin strip at each side and leave the center
attached to firewall.
Two vertical ribs on each side of the firewall, plus two triangular
pieces that rivet to the lower W/S frame corner. Lots of rust and
these rivets will pull right out.
More lengthy comments here:
http://forums.corvetteforum.com/show....php?t=1520953
NHvette is offline   Reply With Quote
Reload this Page Front Clip
Tags
70, clip, corvette, front
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
California front clip SJackson C3 General 21 09-10-2005 11:16 AM
Anyone ever install a front clip? KevinH C1 & C2 Corvettes 13 04-13-2005 09:03 PM
one piece front clip or 3 piece panchop C1 & C2 Corvettes 18 12-28-2004 08:11 PM
new frame for 69 vert whats it worth??? Bills69n84 C3 Tech/Performance 13 11-09-2004 12:51 PM
OUCH! I was warned to support the front clip (dialup beware) 73Gator C3 Tech/Performance 34 03-03-2004 04:10 PM
70-72 FRONT CLIP AND OTHER PARTS FOR SALE Belly's72 C3 Parts for Sale/Wanted 27 10-27-2001 10:05 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
