t-top fitment question
The glass t-tops on the 80 vette we got a couple of months ago don't seem to fit right at the rear, where the pin goes into the body to hold them on. The pin hits the body about a half inch or so too far out from the hole it's designed to fit in. I can get it to fit by putting some force into it, but I worry about the tops cracking. Both sides are the same, with the driver's side being a little worse.
I could really use some ideas about this one.
Received 1,470 Likes
Cruise-In II Veteran
New weatherstripping? New weatherstripping can hold up the tops until it takes a set.
Glass tops fit about 1/4" above the halo panel at the rear of the tops. They do not fit flush like the fiberglass tops.
The passengers side on my 79 does not fit properly either. The tops are the M1131 blue mirror tops that are supposed to be fragile, so I'm afraid to play with them.
http://forums.corvetteforum.com/show....php?t=1436983
If you find a solution please post it.
I did try the fiberglass tops from our other 80, and they fit fine. The weatherstripping doesn't look to be in too bad of shape on the glass tops, I don't think anyway. I just can't figure out why they don't fit better. I have to push on the edge so the pin will fit into the hole in the rear. I'm afraid I'm going to crack them one of these days.
St. Jude Donor '05
The tops on my '79 are a snug fit -- more snug if they've been off for a while. The weatherstripping expands, and they require quite a bfiot pressure to put them on. I don't feel like they're going to break, though.
The tops are adjustable. If you have the painted tops you will have to remove the liner then you will see the bolts that hold the part that goes into the body called a spade. I have seen the spades bent on some tops. The best thing to do if there bent is to replace them. Also there are shims made that mount under the spade to achieve proper fit. I would put some masking tape on the edges of the painted surfaces so as to avoid any paint damage.
Good Luck
Steve
Good Luck
Steve
Having the same problem on my 79. The seals are supposed to be new per the previous owner, but appear loose. I am planning to take the weatherstripping off and see how the tops fit. If they fit fine without weatherstripping, I am going to replace the weatherstrip.
The "ears" that go towards the inside of the car, and the pin that fits into the front on the t-tops fit great, it's the darn pin that slides from the back of the tops that doesn't fit right. It's way too far towards the outside of the car. Is this included in what can be adjusted? Thanks for the help.
-Pete
-Pete
I believe the switch assemblies (are actually switches for the factory
alarm) that the pins slide into are adjustable. Loosen the three screws
that hold the switch assemblies in place and try to move them to align
with the pins.
with the pins.
Originally Posted by lg4vette
Steve, on glass tops, what is the method you'd suggest to adjust them? I'm not sure how to go about doing it.
Good Luck
Steve
