Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-14-2006, 08:53 AM   #1
Vette Gator
CF Senior Member
Vette Gator's Avatar
Default How does the alarm system work on a 76?
My car came without either of the two fender switches (both the keyed one you see from the outside and the one bolted next to it), but the rear horn is in place. I'm in the process of installing the missing parts using the assembly manual, but wanted to know how it's supposed to function when it's complete. When you turn the key and the hood and doors are closed, should there by any sound to let you know that the system is armed? If a door or the hood is opened, should the horn go off continuously or does it eventually shut itself off? Without ever having seen one working correctly, I'm shooting in the dark as a I put it back together and troubleshoot.
Vette Gator is offline   Reply With Quote
Old 07-14-2006, 09:03 AM   #2
...Roger...
CF Senior Member
...Roger...'s Avatar
Quote:
There is no arming sound.I dont think it will shut off until it is turned off.Its just a relay and a flasher.
...Roger... is offline   Reply With Quote
Old 07-14-2006, 11:10 AM   #3
BenUK
CF Senior Member
BenUK's Avatar
I have a '76 and I'd love to know more about the alarm too. My car has the body keyswitch and the horn but I've never seen a second fender switch. Could you give more info please? Do you have any photos or diagrams I could see?
Thanks for any info you can provide. My alarm's never worked, but maybe only because I've never tried. I don't have a key for the fender lock.
BenUK is offline   Reply With Quote
Old 07-14-2006, 11:24 AM   #4
classiczx
CF Senior Member
My original alarm is supposed to work but disconnected for shipping i'm told. But i'm worried about a 30 year old alarm system malfunctioning and locking up the car to have someone check it out & reconnecting the wires... or something like that.
classiczx is offline   Reply With Quote
Old 07-14-2006, 12:30 PM   #5
Greg
CF Senior Member
Greg's Avatar
Location: Palm Springs....but it's a "dry" heat, CALIFORNIA
If your alarm malfunctions it won't lock up the car.
It works on the same principle as your interior lights. When the system is armed and the hood or door is opened the horn is energized. It is interupted by a simple signal flasher so the horns sounds on and off until it is reset with the key.
This basic system is usually pretty easy to get working. Install new door switches, flasher and horn, if needed, and you've covered the whole system.
Greg
Greg is offline   Reply With Quote
Old 07-14-2006, 12:37 PM   #6
gq82
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
gq82's Avatar
Greg
Pretty simple system....I don't know if it's the same horn but the one on my 71 sounds like a dieing goose.
gq82 is offline   Reply With Quote
Old 07-14-2006, 12:46 PM   #7
classiczx
CF Senior Member
Thanx for the info!
...so it's just all flash and noise then... guess i'll let an alarm tech have a looksee and maybe add another alarm with additional features to go along with it.
Old 07-14-2006, 03:11 PM   #8
Vette Gator
CF Senior Member
The other switch is inside the car, and it appears that an arm on the keyed switch must hit it when the alarm is turned on. It looks like the switches on the headlight mechanisms that trigger the headlight warning light on the dash (not sure if they're identical or not, but they look similar). I have the picture in my assembly manual, but since I'm at work, I can't give the page number (it's near the back). Interestingly, I checked out a friend's 75 last night, and that year only had the key switch. The worst part is going to be getting access to this area. I can't imagine why a former owner would have removed the switches. It looks like a lot of work!
Old 07-14-2006, 03:24 PM   #9
BenUK
CF Senior Member
BenUK's Avatar
Thanks for the info.
Before my recent repaint I removed the lock switch from the body and it wasn't too difficult to access that area once I'd removed the washer fluid bottle from that fender. You have to work at arm's length with a big pair of pliers but it's all pretty accessible.
Incidentally I'm pretty sure there's no additional microswitch on my fender. There are no external mechanical components to the lock switch on my car - just two electrical connections (red and purple, I think) so there are no moving parts to activate another switch.
My car was built in May '76 - maybe later ones had a more sophisticated system?
Old 07-14-2006, 04:28 PM   #10
Mark PittPayne
CF Senior Member
Mark PittPayne's Avatar
I wish you luck. If you can get the alarm to function properly then you should get a job at GM. The systems were junk. They worked alright....all the time whether the door was opened or not. I'm not sure on this but I think there was a thread where removing the Ttops would also set it off and that was a major cause for original alarm failures. As I said not 100% on that one.
Gitter done.
__________________
Mark
(Despite what my Avatar Says)
http://corvettepitstop.co.nr
Mark PittPayne is offline   Reply With Quote
Old 07-14-2006, 04:30 PM   #11
...Roger...
CF Senior Member
Gator that switch inside the body is a tamper switch
Old 07-14-2006, 04:34 PM   #12
...Roger...
CF Senior Member
QUOTE-I'm not sure on this but I think there was a thread where removing the Ttops would also set it off and that was a major cause for original alarm failures. As I said not 100% on that one.
Gitter done.[/QUOTE]------------------Mark------I think that started in 78--when the T-top release went to a single handle
Old 07-14-2006, 05:16 PM   #13
classiczx
CF Senior Member
Its probably not practical to actually have the original alarm activated on a daily basis... but it'll be cool just to have it working.
Old 07-14-2006, 05:33 PM   #14
MartyW
CF Senior Member
Support Corvetteforum!
MartyW's Avatar
Send a message via AIM to MartyW
Quote:
The T-Tops on my 76 only have a single release handle. You think my previous owner gots tops off another year? My vin says it was made in January of 76.
MartyW is offline   Reply With Quote
Old 07-14-2006, 05:49 PM   #15
Vette Gator
CF Senior Member
Aha! Now the assembly manual instructions make perfect sense. I couldn't understand why they said to make sure that the button on the inside was up against the keyed switch. I thought it meant that should be in contact when an arm was moved. Now I see that it means with the barrel of the keyed switch to set the alarm off if someone tried to remove it. That's pretty clever!
Old 07-14-2006, 06:10 PM   #16
BenUK
CF Senior Member
BenUK's Avatar
Quote:
Definitely 2 release handles on the T-tops in '76.
Old 07-14-2006, 06:27 PM   #17
MartyW
CF Senior Member
MartyW's Avatar
Quote:
I wonder what year they are from. The more I inspect the car the more wierd things I find. When I went to recover the seats last week I found out that I have 1st Generation 68 seats instead of my correct 76 seats so I had to recover with 68 seat covers and backs. Now it seems that I got later year T-Tops. Oh well, I guess the car is a Frankenstein car. At least it looks ok
Old 07-21-2006, 02:48 PM   #18
Vette Gator
CF Senior Member
Which way should the key slot face when the alarm is turned off - straight up or side-ways? I am trying to figure out which orientation before I clip the new key switch into my fender.
Old 07-21-2006, 03:19 PM   #19
BenUK
CF Senior Member
BenUK's Avatar
The hole in my fender is shaped in a way that means the switch only fits one way, but I'm sorry, I can't remember which it is.
Edit: I think the clip at the back of the switch slides horizontally to hold the switch though, and that only fits one way. Maybe that helps.
Old 07-21-2006, 09:51 PM   #20
KenSny
CF Senior Member
KenSny's Avatar
76 is the same as a 75. I wrote a procedure to troubleshoot and repair the complete factory alarm system. I posted it here a few years ago. If anyone wants a copy of it just email me.
KenSny is offline   Reply With Quote
Reload this Page How does the alarm system work on a 76?
Tags
1971, 1976, 76, alarm, c3, corvette, factory, fender, interior, key, lights, pictures, sounds, system, work
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
