What's your oil pressure?
05-25-2006, 09:15 PM
Curious as to what others have for idle and driving oil pressure.
05-25-2006, 09:34 PM
79 L 48 with 16,000 orig. miles. Engine warmed up-idle 20lbs to a
max. of a little over 40lbs at 3000 RPM. (65 mph)
05-25-2006, 09:47 PM
Quote:
Mine is about the same as chevylits. Engine warm at idle around 20lbs and cruise right at 40 lbs. Mine is a 77 L-48 newly overhauled
05-25-2006, 10:05 PM
Warm idle 35. 2000 RPMS 45lbs
05-25-2006, 10:06 PM
05-25-2006, 10:27 PM
same for me
05-25-2006, 10:37 PM
My 355 engine is not stock. I have a HV Melling pump that has 30psi at 600RPM idle and 50psi at cruise. However I've never checked the true pressure using a calibrated mechanical guage.
05-25-2006, 11:25 PM
78 Sa 128 K engine...idle 15-20 psi....2000 rpm 40 psi... 10-30 wt
69 502 idle 30-35 psi.....highway 65 psi...20-50 wt..
05-26-2006, 12:02 AM
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
30psi at idle and 50psi at cruise
05-26-2006, 02:01 AM
Quote:
Originally Posted by Voetsek
70 pounds at idle.
05-26-2006, 02:04 AM
... sorry, I couldn't resist
(don't worry about the temp, I'll fix that gauge just like I fixed the oil pressure one!)
05-26-2006, 02:50 AM
30 to 35 psi @ idle, 55 psi @ 2000, and 70 psi @ 3000 with warm 10W30.
05-26-2006, 03:23 AM
mine about 50-60 when i drive
05-26-2006, 06:53 AM
540....35 at idle, 65 at cruise.....15W40
05-26-2006, 10:16 AM
I had the same with my stock 76.
Idle cold 40
Idle warm little over 20
Driving cold/warm a little over 40.
There is a relief valve on the oil pump that prevents high oil pressure. The stock setup should limit oil pressure to about 40lbs.
05-26-2006, 10:22 AM
05-26-2006, 11:17 AM
05-26-2006, 11:20 AM
St. Jude Donor '12-'13
Stock '78 L48- 40idle 60 under heavy throttle.
05-26-2006, 11:21 AM
05-26-2006, 11:38 AM
35-30 idle 50+ cruise
