Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-18-2006, 01:16 AM   #1
Flagstaff_Vette
CF Senior Member
Support Corvetteforum!
Flagstaff_Vette's Avatar
Default 1972 VIN Codes (Part of a series)
Please Note – this is NOT going to be 100% accurate. Numbers changed, I coulda mis-typed, but this is the best I can do as a back yard mechanic to help you out. This came from 3 different books, and I tried to put all 3 into one page for ya. Please look for the book CORVETTE BY THE NUMBERS for more accurate information. Thanks.
1972 Corvette
DECODING THE VEHICLE IDENTIFICATION NUMBER
For the first time, Engine codes were in the VIN
VIN # is stamped on the inside of the A pillar windshield.
Convertible Vin #’s were 1Z67K2S500001 TO 1Z67K2S527004
Coupe Vin #’s were 1Z37K2S500001 TO 1Z37K2S527004
Symbols, Letters and their meaning:
1st Chevrolet
2nd Z for Corvette
3RD and 4th = 67 Convertible, 37 Coupe
5th Engine
K = Base 350
W = LS5 454
6th Symbol indicates Year (2 = 1972)
7th Symbol indicates Assembly Plant (S = St Louis)
The last six symbols are the production numbers.
1968 – 1978 Corvette Trim Tag ID
Upper right corner is body build date
A = August 1971
B = September 1971
C = October 1971
D = November 1971
E = December 1971
F = January 1972
G = February 1972
H = March 1972
I = April 1972
J = May 1972
K = June 1972
L = July 1972
The Second and Third numbers were the day of the month that production of this car started.
On the left side is a word TRIM followed by the following:
400 = Black
407 = Red
412 = Blue
417 = Saddle
404 = Black Leather
421 = Saddle Leather
Just right of that is the word PAINT followed by the following:
912 = Sunflower Yellow
924 = Pewter Silver
972 = Classic White
945 = Bryar Blue
946 = Elkhardt Green
973 = Mille Miglia Red
979 = Targa Blue
987 = Ontario Orange
988 = Steel Cities Gray
989 = War Bonnet Yellow
ENGINE CODES
1972’s consist of 8 characters:
1st is Assembly Plant
2nd and 3rd are Assembly Month
4th and 5th are Assembly Day
6th is C for Chevrolet
7th & 8th are the Engine Code Suffix
Assembly Plants (Some engines produced at some plants were used in other cars.)
F = Flint Motor Facility (No Corvette Engine this year from this plant)
K = McKinnon Industries (No Corvette Engines this year from this plant)
S = Saginaw Service (No Corvette Engines this year from this plant)
T = Tonawanda
V = Flint Engine Plant High Performance
Code, Engine Size, Horsepower, Transmissions and Options
CDH 350, 200, 4 Speed Rochester 4 Bbl
CDJ 350, 200, THM400, Rochester 4 Bbl
CKW 350, 200, 4 Speed, Rochester 4 Bbl
CKX 350, 200, THM400, Rochester 4 Bbl
CKY 350, 255, 4 Speed, Mechaznical Lifters, Holley 4 Bbl
CKZ 350, 255, M22 4 Speed, ZR1 Performance Package, LT1 Engine
CRT 350, 255, 4 Speed, Mechanical Lifters, Holley 4 Bbl, AIR Injection
CPH 454, 270, 4 Speed, Rochester 4 Bbl, Hyd Lifters
CPJ 454, 270, THM400, Rochester 4 Bbl, Hyd Lifters
CSR 454, 270, 4 Speed, Rochester 4 Bbl, Hyd Lifters, AIR Injection
CSS 454, 270, THM400, Rochester 4 Bbl, Hyd Lifters, AIR Injection
Corvette Engine Blocks (You may have a different block, if so it might be from another Chevy Vehicle)
3970010 350, 300, 350 & 370 HP, 4 bolt main (This block was used thru 1979 year)
3999289 454, 270HP, 2 bolt main
Cylinder Head
3998993 350ci, 175HP, 1.94 intake 1.5 exhaust 75.47 cc
3998916 350ci, 255HP, 2.02 intake 1.60 exhaust 76.18 cc
3973487 350ci, 175HP, 1.94 intake 1.5 exhaust 75.47cc
3973487 350ci, 330HP, 2.02 intake 1.60 exhaust 75.47
3973487X – 350 Engine used in late 72.
3993820 454ci, 365HP, 2.06 intake 1.72 exhaust 113.060
3999241 454ci, 270HP, 2.06 intake 1.72 exhaust, 113 cc
Flagstaff_Vette is offline   Reply With Quote
Old 05-18-2006, 07:44 PM   #2
toolking
CF Senior Member
toolking's Avatar
Tnx
toolking is offline   Reply With Quote
Old 05-18-2006, 07:45 PM   #3
c3dreamer
CF Senior Member
c3dreamer's Avatar
c3dreamer is offline   Reply With Quote
Old 05-18-2006, 09:16 PM   #4
SharkAttack
CF Senior Member
SharkAttack's Avatar
Thanks from another 72 owner. I have most of these, but sure I'm missing something...
SharkAttack is offline   Reply With Quote
Old 05-18-2006, 09:42 PM   #5
PEPTO77
CF Senior Member
PEPTO77's Avatar
So if my engine code has CKY in it then it is a CKY 350, 255hp, 4 Speed, Mechanical Lifters, Holley 4 Bbl without AIR Injection? Smog pump is no where to be found and I have always been told that all 72's had the pump from the factory.
PEPTO77 is offline   Reply With Quote
Old 05-18-2006, 09:56 PM   #6
PRNDL
CF Senile Member
PRNDL's Avatar
Mark Jackson @TraderJaxon
Send a message via AIM to PRNDL
much, but not all of that info available here:
http://www.rowleycorvette.com/stats72.html
and here..
http://www.idavette.net/facts/72.htm
PRNDL is offline   Reply With Quote
Reload this Page 1972 VIN Codes (Part of a series)
Tags
1971, 1972, 350, 3999289, bb, bolt, chevy, code, codes, corvett, corvette, decoding, engine, main, plants, tag, trim, vin
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
