73 BB build
Old 12-14-2017, 10:33 AM
73racevette
73racevette's Avatar
Default 73 BB build
Well I am starting year 3 of my '73 build. Decided to pull together a brief build thread.
Started around December 2015 with this:
Popular Reply
09-03-2019, 10:25 AM
73racevette
And now it is red... Finally after over a year of body work.
Old 12-14-2017, 10:38 AM
73racevette
From this point, it somewhat quickly moved on to this:
Old 12-14-2017, 10:41 AM
73racevette
Original BB
Old 12-14-2017, 10:45 AM
73racevette
After getting to the root of the matter, started the rebuild with a fresh powder coat.
Old 12-14-2017, 10:47 AM
73racevette
Some new brake lines...
Old 12-14-2017, 10:51 AM
73racevette
Some pretty suspension bits from Ridetech as well as something to stop it from Baer
Old 12-14-2017, 10:56 AM
73racevette
Then needed something for the rear wheels, so time to rebuild the rear diff with a tuned posi and some new gears, etc.
Old 12-14-2017, 10:58 AM
73racevette
Old 12-14-2017, 10:59 AM
73racevette
Old 12-14-2017, 11:02 AM
73racevette
Old 12-14-2017, 11:04 AM
73racevette
Needed a new fuel tank because the one I had was full of pinhole leaks everywhere. argh.
Old 12-14-2017, 11:07 AM
73racevette
On to the engine....
Old 12-14-2017, 11:10 AM
73racevette
After some inspection, magnaflux, etc. Found the block to be cracked in 3 separate cylinders. This is getting spendy now.
Decided after much debate to go with a new GM block and a Scat balanced stroker rotating assembly for a healthy 488 build. Zero'd the deck and put on some Brodix Heads, Straub roller cam, roller lifters, etc, etc. Around 10.5:1 compression should get it down the road ok.
Old 12-14-2017, 11:13 AM
73racevette
Old 12-14-2017, 11:17 AM
73racevette
ceramic coated headers
Engine back in the frame
Old 12-14-2017, 11:19 AM
73racevette
Originally had a TH400 tranny, but decided to go with a TKO600 tranny.
Old 12-14-2017, 11:20 AM
73racevette
Front of the engine mostly put together with a March pulley system, Dewitts radiator, remote PS reservoir and a borgenson steering box.
To 73 BB build
Old 12-14-2017, 11:22 AM
73racevette
rudutch (12-14-2017)
Old 12-14-2017, 11:25 AM
73racevette
It has been a long 2 years so far. Hopefully this next year, I will get some wheels and tires on it and set it back on the ground. Then time to start it up and go to work on the body. Thoughts right now are to have fender flares on it. The back quarter panels need to either be replaced or have flares put on, so seems flares go best with a stick and a stroked 454. Will have to see where this goes. Hope to be driving it in 2019.
Old 12-14-2017, 03:59 PM
Metalhead140
Metalhead140's Avatar
C3 of Year Finalist (track prepared) 2019
Awesome!! Very cool, keep us posted.
73racevette (12-15-2017)
Quick Reply: 73 BB build
