Gauge Specs
Gauge Specs
Hey, I'm about to order a set of AutoMeter Ultra-Lites and I just need a quick answer on what specifically to order. The engine in my 75 is stock as is my distributor and entire drivetrain.
I think that I want the 2 1/16 size, right?
What size should the speedo and tach be?
should each gauge be electric or mechanical?
Any suggestion on number values for the faces or should I stay with stock?
I think I want volts, water temp, oil pressure, fuel level, and I want to add trans temp in place of the clock. is there a more valuable gauge to replace the clock with?
Thanks.
Thanks.
these r the ultra lites, 2 1/16 size. didn't do the speedo or tach so don't know the size. i did the tranny temp seeing i've got a 200r4 tranny. as i recall mine r all electric cept the oil pressure. not sure on the 75's
archives had nice pics but no specifics. thanks for the info. ordered today and will post pics sometime in the next 5 years when I'm done.
