whoo-hooo! My baby's going to Bowtie OD!
After finally coming to the conclusion that it will be a very long time before I find the time to change my tranny myself, I broke down and am going to let someone do it for me
I didn't know it till I posted a thread about area tranny recommendations, but as it turns out, I live very close to Bowtie Overdrive.
I drop it off next Friday and they will be transplaning a beautiful, shiny level 2 700r4.
Sorry for wasting bandwidth with this, but I'm stoked!!!
Just in time for a long drive up Hwy 1 next month. LA all the way up to Washington.
last night i installed bto's 700r4 lockout kit. pretty easy installation considering ive never seen the inside of my trans b4. i think your smart letting them do it all, especially if it acts up. looking foward to hearing what a dialed in 700r4 is like.
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Originally Posted by jdmick
I've only got a few miles on my 700r4 so far but I can tell you IT IS SWEET!!
20%??
Originally Posted by Zoomin
I wonder what kind of MPG improvements you can expect by going to an OD tranny.
20%??
20%??
There is a sort of funny disclaimer on the BTO website. In summary, it says that many people realize very little mpg gain with their transmission because they have a tendency to drive faster with it!
I'm really looking forward to it. I haven't really heard anything bad about them, with the exception of some frustration while installing and adjusting the tranny. I won't have that problem since they are doing it.
Am running a BTO 200 R4 level 2 with 3:73 gears, the difference is amazing!
BTW cchristo, noticed you plan on driving up the Coast Highway, the Devil's Slide section south of Big Sur is closed (as the name implies, because of a landslide), looks like it will be for a while, Cal-Trans website should have detour info
Highly unlikely that it will be repaired for quite some time but as I get closer to leaving, I'll check on alternatives. It now looks like I might end up having to fly anyway
20%??
20%??
If you see Steve at BTO tell him that he's got a very happy customer in Limey-land (if you're gas prices ever hit what ours are then you'd understand why happiness is an OD gear)
20%??
20%??
i went from 9 mpg to 17 mpg,,373 rear end, the th 350 had me doing 3200 rpms at 60 mph,now im at 2200 at 80 mphand when you peg it its at 135 before your can realize,,well the 431 hp 532 torque probably helps a little
Originally Posted by Kalway
What does BTO charge to do it?
That includes the tranny, torque converter, crossmember, TV cable, drive shaft work, etc.
Obviously, I don't know what type of MPG I'll be getting, but I figure it will work out at least this good.......
Miles Driven Avg MPG $ Per Gal $ To Drive $ Saved
50000 13 $2.85 $10,961.54
50000 17 $2.85 $8,382.35 $2,579.19
Arrgh, I can't make these columns line up! Well, bottom line is that it will take about 50,000 miles of driving for the new tranny to have completely paid for itself!
Originally Posted by cchristo
It's going to be a little over $2500.00
