pics of 245/60/15 front 255/60/15 rear
Well, I was thinking about getting new 17" rims and tires but some unforseen repairs have depleted my "mod" money. I really am going to need new tires soon so I'm going to keep the stock ralleye rims on my 72. I'm thinking about going with 245/60/15 in the front and 255/60/15 in the rear. Anybody have pics of this combo? I would like to see what the vehicle stance is like and how good the wheel wells are filled. Also any advice on brands is appreciated. I'm leaning towards the bf goodrich ta's.
Thanks for any info
Thanks for any info
245/60R15 front and rear. MUCH better then the 225's that were on it when I bought the car.
The guy at tire rack says "Wow those are big tires, are you sure they will fit?" LOL
here is a pic stock (235 70's) VS the (255 60's)
i since gone to 17's on the sidepipe car and move the 255's to
the other car. i have run 255's on several vettes no problems
For you guys running the 255's all the way around, I've read that there can be problems with rubbing, etc with this size, especially in the front. Have any of you experienced that?
Friend Request Magnet
Which brings up this idea;
since you are keeping the stock ralley's for now, you may as well go the same size all the way around until you get the custom rims (whether it be safely with 245's from git-go or 255's).
Most *good* tire shops will mount at least one front and check for rubbing before they mount all 4.
With same size; you can then rotate the tires and keep them in great condition, which will enables you to re-sell them if you choose once you get the custom rims.
If you want to resell and have different size tires front vs. rear, you will have to find the right buyer...
All 4 the same size will fit just about all 15" applications including trucks...giving you a broader market for resale.
I have 255x60 all the way around and no rubbing issues...I have seen (and read) that a lot of other CF members have 255x60 front and rear with no rubbing either.
Good Luck,
Jim
Rich
1 Post
Originally Posted by Jims79
I don't know how this helps but I have 245/60/15 front & 255/60/15 rear. Had the 255 up front and they rubbed.
Originally Posted by rihwoods
I used to run 255-60-15's on my 78..had to trim wheel well lip on driver side....otherwise,all was ok....this seems to be a hit or miss deal..some don't rub..some do..
Rich
Rich
1978
RPO QBS P255/60R-15 White-letter steel-belted radial tires ($216.32)
In this picture my car has 235/60/15 on front...275/60/15 on the rear. The rears rubbed the inner finders when I hit bumps. I now have 245s all the way around.
James
James
