Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 General
General C3 Corvette Discussion not covered in Tech Sponsored by
Corvette America
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-24-2005, 10:06 AM   #1
fishwater
CF Member
Default VIN location on frame of 1979?
I am "trying" to locate the original vin for my 1979. It has had a state issued vin b/c it was stolen when it was newer. My state has charged me $20.00 to do the research but can't promise that it will find the info. I am considering selling it & buying a bumper car or restoring this one. The car is black but doesn't look to be original. Has an L82 (checked the numbers) & a four speed. The tach is a correct L82 but the speedo looks aftermarket. Probably replaced when first stolen? The car was never hit & still has the original ball joints (big fat rivets) I am on the fence & starting to obsess about the VIN. I am told they are stamped on the frame but no clue where & will I be able to see it easy? I can see the tank sticker on top of the tank but can't read it. Eventually if I go further I will drop the tank & hope it isn't faded.
fishwater is offline   Reply With Quote
Old 10-24-2005, 10:47 AM   #2
johns73
CF Senior Member
you will find the vin stamped on the driver side frame rail right across from the top of the tire it will be hard to see. It's rignt on top between the body and frame.
johns73 is offline   Reply With Quote
Old 10-24-2005, 10:51 AM   #3
Twin_Turbo
CF Senior Member
it's on the top of the frame rail, drivers side directly behind the rear wheel, it's a pita to see though.
Twin_Turbo is offline   Reply With Quote
Old 10-24-2005, 12:01 PM   #4
fishwater
CF Member
Of course the way my luck has been the frame is undercoated & I can not see a thing. Are the numbers between the two bolts that hold the brake line down? How big are they approximatly & are they written across the frame as you look in the wheel well?
I am using a mirror to follow the top of the frame rail, I can clearly see the rail from the front of the tire to the body mount. So far no numbers, I imagine the undercoating is in the way?
Old 10-24-2005, 01:34 PM   #5
Twin_Turbo
CF Senior Member
the numbers are on top of the frame, there's no brake line back there, if there's any line it's an evap line
Old 10-24-2005, 02:09 PM   #6
fishwater
CF Member
It sure looks like a steel brake line to me?
Old 10-24-2005, 02:10 PM   #7
NHvette
CF Senior Member
NHvette's Avatar
... should be stamped into the steel. Also, there might be a set
just forward of the drivers side #3 body mount (which is
impossible to see without lifting the body). Some lacquer thinner
and Qtips might clean the top of the frame rail enough to make
them out. I have also read about using an inspection mirror to
see them better ... good luck.
On the frame kickup - next to the top of the rear tire - is the fuel
vapor line. Follow it back and up to the top of the tank. Rear brake
lines are at/along the lower differential (called rear) crossmember.
NHvette is offline   Reply With Quote
Old 10-24-2005, 02:16 PM   #8
Twin_Turbo
CF Senior Member
It's a steel line, it runs from the tank to the evap canister on the drivers side frame rail under the brake booster
Old 10-25-2005, 07:10 AM   #9
fishwater
CF Member
looks like I will have to try some thinner on the frame & hope I can see something. How big is the vin? One inch long? Three inches long?
Old 10-26-2005, 08:48 PM   #10
NHvette
CF Senior Member
NHvette's Avatar
Honestly, I don't ever recall looking for mine when restoring the frame.
I will try to look at the remains of my 75, but with all the rust
it had, don't expect much.
Reload this Page VIN location on frame of 1979?
Tags
1979, 79, c3, corrvette, corvette, engine, find, frame, locate, located, location, locations, on1979, vette, vin
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
