Front wheel bearings & seals (part#)
Old 12-28-2022, 05:45 PM
Novusuhu
Novusuhu's Avatar
Default Front wheel bearings & seals (part#)
Hi everyone
I'm currently rebuilding/restoring the complete front suspension of my 77 Vette.
I have most of the parts and tools that are needed.
I just don't know what type parts (model#) I need, to replace the front wheel races, bearings and seals with.
I read Timken is the way to go.
Do you guys know all the part numbers for this job?
I'm from Belgium (Europe).
Old 12-28-2022, 06:40 PM
interpon
Support Corvetteforum!
interpon's Avatar
Received 2,026 Likes on 1,552 Posts
Try rockauto? I would think national or timken
Novusuhu (12-29-2022)
Old 12-28-2022, 07:20 PM
z06roadkiller
z06roadkiller's Avatar
St. Jude Donor '12
I just di mine on my '68...most of the rebuilders use Timken bearing sets. You need front inner and outer bearing sets plus an outer seal (Timken 7934S).
Old 12-28-2022, 07:35 PM
Novusuhu
Novusuhu's Avatar
Is a 68 the same as a 77, regarding bearings and seals?
Old 12-28-2022, 11:00 PM
GTR1999
GTR1999's Avatar
Received 2,617 Likes on 1,338 Posts
no the bearings were smaller in the 63-68’s
Old 12-29-2022, 08:44 AM
Mooser
Mooser's Avatar
Received 3,139 Likes on 2,070 Posts
19768 SKF - TIMKEN 9406S Wheel Seal
TIMKEN SET5 Wheel Bearing
TIMKEN SET3 Wheel Bearing
that was what I used on my 72.
M
Old 01-12-2023, 07:44 PM
Novusuhu
Novusuhu's Avatar
Thank you all guys!
Today I got the Timken bearings and seals by post.
They look good! Just what I needed.
To Front wheel bearings & seals (part#)
Quick Reply: Front wheel bearings & seals (part#)
