Performer RPM VS. Performer RPM Air Gap
Which is better. several forum members recommed the performer rpm. But whats the difference in the two and which one is better thanks.
RPM, torque; RPM Gap higher revs
The Gap gives you more horsepower and higher rpm. But, it is a hood clearance issue. The RPM will give you better low end torque, but runs out of air flow in the 6000s. If you can live with no clearance and a little pretend breather, you can get max horses out of the Gap.
will it fit under the l-88 style hood
