Dumb Indicator Light Problem - 1970
Old 09-06-2005, 10:46 PM
stingry
stingry's Avatar
St. Jude Donor '05-'06
Default Dumb Indicator Light Problem - 1970
Have a 1970. The amber lights on the left and right SIDE of the front fender light up with the headlights but DO NOT flash when the front turn signals (indicators) flash. Is this normal for a 1970?
A friend has a 1972 and his fender lights flash out of sync with the front turn signals but they DO flash.
What do yours do?
Thanks in advance.
Pete
Old 09-06-2005, 11:04 PM
SteveG75
SteveG75's Avatar
The fender lights should flash and they do flash out of sequence. It has to do with how GM grounded the bulbs to make them flash since they only have one filament in them. If they are not flashing, check the bulbs then all the wiring.
Old 09-06-2005, 11:31 PM
stingry
stingry's Avatar
Steve,
Thanks.
Will try tomorrow.
Pete
Old 09-07-2005, 12:11 AM
SteveG75
SteveG75's Avatar
Pete,
Found the info I used to help trouble shoot my '75. Fortunately, most of the systems are the same:
http://www.corvetteforum.net/c3/tune...l/index6.shtml
Basically, when I hit my horn, my indicator lights came on. Bad ground from the radiator to the frame. This page has some great info on how the turn signals and such work.
Later,
Steve
Old 09-07-2005, 02:40 AM
Hammerhead Fred
Hammerhead Fred's Avatar
On 71 & 72 year models, the front side markers flash "out of sync" from the front turn signals when the headlights are on; they flash "in sync" with the front turn signals when the headlights are off. Don't know that the side markers flash at all on a 70 though.
Old 09-07-2005, 10:47 AM
Z-man
Z-man's Avatar
Hmmm...I never thought the side marker lights on my '70 were part of the turn signals. I'll check the schematics when I get home tonight...
Aha! Just as I thought. The side marker lights on the '70 are not connected to the signals.
Old 09-11-2005, 07:52 PM
stingry
stingry's Avatar
Z-man,
According to the later C-3 schematics they ground the light to get it to flash.
It does appear that for our year that the marker ight has +12v and ground and no connection to the marker cct.Checked all my grounds and all seems good.
Anyone else have a 70 that the marker lights DO or DON'T flash???????
Thanks,
Pete
I cannot tell if the 70 schematic is the same as laer years at first look. Going to keep tracing.
Old 09-12-2005, 12:14 AM
Sandiego70
Sandiego70's Avatar
I agree with schematics and also my service manual does not mention the sidemarkers with signal operations either. Mine do not flash on my 70, but work just fine when lights are on as side markers ( no signals flash )
Old 09-12-2005, 09:56 AM
70inSBIn
70inSBIn's Avatar
Was this a mid year change maybe? Mine flash and I know the wiring is oem.
Old 09-12-2005, 10:19 AM
Eddie 70
Support Corvetteforum!
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
My 70 side marker lights do not flash either. I tried with the headlights on also just for kicks.
Old 09-12-2005, 01:10 PM
stingry
stingry's Avatar
Mine is a late 70 so I am surprised it doesn't flash.
Where are those Gm engineers when you need them!
Old 09-12-2005, 01:36 PM
Z-man
Z-man's Avatar
I wonder if there are Vettes that have poor grounds or weak electronics that cause the side marker lights to *appear* to flash when the blinkers are on - and it's just the extra current draw that makes the side markers dim. That would explain the "opposite" flashing...
Old 09-12-2005, 02:02 PM
Eddie 70
Eddie 70's Avatar
My car is 9790 so you can compare that to your car if that would help in determining early or late.
Old 09-12-2005, 07:10 PM
cosmicvette
cosmicvette's Avatar
I just went and checked the side marker operation on my 70:
The side markers turn on when I have the headlights on.
The side markers do not flash with the turn signal on.
My 70 is an early 70 (January build).
Old 09-12-2005, 07:38 PM
Z-man
Z-man's Avatar
Mine's 9048...13th of May. No flashing...
Old 09-12-2005, 11:18 PM
stingry
stingry's Avatar
Thanks everyone so far.
Mine is 16531. I think that is a late build as they only made about 17500 that year.
In my other post someone mentioned light bulbs. Changed them. No difference.
I would like to know the build number of peoples cars that do flash.
This riddle is yet to be solved!
Cheers,
Pete
Old 09-12-2005, 11:27 PM
stingry
stingry's Avatar
But wait there is more....
Looks like it is a bulb issue. I have changed from the "orange" bulb to clear WTF??? Apparently this may be the problem.
http://forums.corvetteforum.com/show...post1552046986
To Dumb Indicator Light Problem - 1970
Old 09-13-2005, 10:59 AM
Z-man
Z-man's Avatar
It seems to me that, unless your wiring is different than the schematic, you would have to have "Xmas tree" type self-flashing bulbs to get the markers to flash. There isn't a flasher in the circuit. (And then they would flash all the time they were on).
Old 09-13-2005, 10:57 PM
stingry
stingry's Avatar
Z-man, Cosmic, Eddie,
Do your marker lights flash when the emergency flasher is pressed?
Well this is seems like an epic larger then Star Wars. I went and changed all my bulbs and checked my flasher. I have the following:
All Marker Lights - 168 Bulbs (single filament)
All Turn Signals - Orange Bulb 1157A (double filament)
Reverse Lights - 1141 Clear Bulb
Flasher - Heavy Duty - 536
I am starting to trace the schematic tonight. I have a 72 manual to compare to my 70 manual. See if they are the same or diiferent. I have a friend with a 72 and his marker lights flash as do some other people o the forum.
I need the corvette fairy to come and fix my lights!
Cheers,
Pete
Old 09-14-2005, 11:13 PM
70inSBIn
70inSBIn's Avatar
Default False Alarm
False Alarm. Man, I appologize. I could absolutely, positively, swear that my corner lamps blinked because I just put the lights back together a few months ago after paint, and I put in new bulbs where needed and double checked all of them for function.
Well, after this thread got started, I decided to go out and check them so I could report back. Well they are NOT blinking. They stay nice and steady when the signals are blinking, which would seem to match the schematic shown in the earlier post.
I guess I was mistaken. Sorry about that. I still think a gremlin must have snuck out and changed them. I was really sure they blinked as recently as a couple weeks ago, when I checked the bulbs again. The only thing, is I know I have a bad ground on one of the rear tail lamp housings. But I dont know that that would do anything with the corners. Its possible I have a fluke scenario here and I will keep an eye on them, but they really appear for the moment like they are not supposed to blink.
Quick Reply: Dumb Indicator Light Problem - 1970
