floor seat belt retractors don't fit
Hi to everyone. This is my first post on the forum although I have been reading it for a few months and enjoy the many topics that are discussed. I really need some advice and I'm sure someone can help. I have a 76 with a 75 frame and new floor pans bought from Paragon in Michigan. The guy that did the work did not instal the seat belts(originals) when the car came back. I have tried every possible way to make the floor retractor fit.The hole that is there matches a hole in the frame but when I bolt the retractor in, the seat can't go in, the retractor is to high. There is a square dip in the pan where the retractor fits but it doesn't when you align it with the hole made in the pan and frame. I don't remember where the retractor fit before the new frame. The entire floor and carpeting were really rotton I will try posting pics later tonight. to hot out there now Thanks for any advice. Gary
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
My 75 retractors don't bolt to the frame. There is a reinforcement welded to the rocker channels for this purpose. I thought there was no change in 76, but I could be wrong.
Originally Posted by Ed T
be sure to put a plastic spacer between the floor & the retractor. this will allow the retractor to swivel and not rust fast to the floor.
Thanks for the great pics. I see how the retractors fit but I have a hole in the pan to the frame to bolt them in. Obviously not right from what I see from the pics.When I lay the retractors in the way you showed me, they do allow the seats to fit over them. Now what, I would have to drill a hole in the pan but where would I get the weld nut and reinforcement? It seems that bolting to the frame is a lot safer but I know they can't. There must have been an area stamped on the new pans that were thought to be the seat belt bolt holes why else would the guy that put the pans in do this. I should talk to this guy but he's so hard to get a hold of. I wonder if any C3's with a harness are bolted to the frame. Thanks again, pictures say it all. Gary
Here are some pics that were taken yesterday. As you can see we have applied and sound deadner and a heat shield to the floor pans. The seat retractor can only be bolted in as shown. Your advice in how to fix this problem is excellent. Hope this helps with showing the problem. Thanks, Gary
You should be able to rivet a reinforcement plate to the bottom of the pan. That is what I did for a seat frame bolt. Great advice above on the plastic spacer. When I put in my seatbelts only one had the spacer, the other doesn't. I hope it doesn't cause me too many problems down the road.
I know what I will be doing this weekend. Thanks for excellent advice. The vette came back with all the interior removed except the dash.All the nuts, bolts and screws were in a bag. Looking at your pics now tells me what looks like" handles", are made for. The hole that the retractor is bolted to must be one of the holes for which are the guides for the belts. I will look for the other in the frame. This vette has been gone to the vette doctor more than its been in my garage. We never thought we would buy an older vette and look where it has taken us, but it's been a lot of fun and $$$. Just starting to do the interior, the carpet is first on the budget but will need to also put the interior trim pieces in the rear deck. I will probably need help with that too since I haven't seen the car together since last November. Thanks a million. Gary
