First C3.... Already having problems..
Hello! I just bought a 1976 Stingray and I'm already having issues. I got home the first night and all of the sudden the hazard lights started going off. I went to pull the switch and then the screw came right out. It won't thread back in (I think the inside is stripped) and I don't know how to shut them off. For now, I pulled the flasher off of the fuse box so it would stop the hazard lights, however, now I don't have blinkers. Help!!!
Ps. I'm new here so I am sorry if this is in the wrong section
Zen Vet Master Level VII
Welcome to the C3 Tribe!
I'd start with a super small needle nose pliers or thin screw driver and see if I could pull out the switch shaft. Once the shaft pulls out, you can do a diagnosis and see if it is stripped or not.
Failing that, you may have to take your steering column apart. Not a bad job if you are handy. You can get to the switch pretty easy and fix or swap.
A suggestion is to buy two manuals. The first being the factory service manual and the AIM (assembly Instruction Manual) so you can see how things go together. It will save you countless hours. Ebay has them quick, dirty and (sometimes) cheap.
Good luck!
Good luck!
Jack Reak (08-23-2016)
Good luck!
Good luck!
Received 2,878 Likes
Hi Jack,
I'll say welcome too.
A very good source of steering column information is Forum member Jim Shea.
He has terrific illustrated information about servicing steering columns. He is THE steering man!
If you use the search tool for his name you'll be led to his posts and you can then look for info about your flasher problem.
Good Luck!
Glad you're here!
Regards,
Alan
Good Luck!
Glad you're here!
Regards,
Alan
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Welcome Jack to the forum.
And get used to working on your C3.
These are 40yr old cars and they need lots of TLC.
Look at it like playing with your dog...and not as a chore.
Enjoy!
Bman (Dennis)
Enjoy!
Bman (Dennis)
Welcome
The "already having problems" is typical when first purchased.
Often times that loving feeling goes away, then things start to break/wear out and they get neglected/sold, until sorted out by the new owner.
Expect the worst, hope for the best.
Yes... welcome and congratulations on owning the most beautiful vehicle ever manufactured...
Agree... completely don't sweat the small stuff... you know what - after the next ten years of going through that thing - it will be perfect. Ha!
Manuals will help... patience is a virtue.
St. Jude Donor '17, '19
Hello and welcome to the gang!
The c3s will have things sneek up on you like that, so don't freak out. And there will always be things you want to do to it or needs to be done.
I do recommend the books mentioned by billschroeder5842, but I would also suggest buying one of those guided books, like chilton. They explain the manuals billschroeder5842 suggested and helps make for an easier read.
Nam Labrat
Received 4,153 Likes
Welcome to the Forum. 3 years ago I didn't know how to open the door on my basketcase '68 convertible.
With lots of advice from Forum Members I've learned to rebuild trailing arms/speedometers/etc.
You can do this!
You can do this!
Welcome to the joys of owning an older car. There will be always one thing more to fix, and then there is the while is am at it disease. Most of us have it, and it is incurable until you get rid of the car. I went to turn on my windshield wipers and the **** disintegrated into dust! Hazard flashers were or are rarely used and like most switches this can cause issues when you need them. Fortunately not a big deal once it is fixed.
bagger88 (08-25-2016)
2018 C3 of Year Finalist
Well timed, I just walked in from the garage having wiped the drippings off the floor...Fluids Checked!
So not to hijack the thread, I have a rebuilt TT column but the flasher button is frozen in the off position. I've decided to just leave it as is.
Btw...isn't the hazard warning relay a separate component from the flasher relay? My warning relay was mounted on the fuse box and the flasher relay was mounted behind the glove box panel on my 1969.
Regards,
Tom
