327 Engine Block and Camel Double Hump Heads
For sale 62-63 Chevy 327 CE 957 57 dated J 10 8 (10/10/68) casting number 3959512. Engine is 30 over and was smoking when removed from car. Includes oil pan, balancer, pistons,
etc. Excludes intake manifold, heads, etc. $300.
For sale 2 camel double hump heads removed from block above. Both casting numbers are 3782461. Date codes E 18 5 (5/18/65) and A 19 3 (1/16/63). $200 for pair.
Thanks for looking.
Thanks for looking.
Do you know if that CE 3959512 block is a large journal? Sounds like it should be if its a 1968 block and very hard to come by if it has the crankcase vent hole in the back of the block.
