FS/Chevy BB engine parts
These parts were on a 496 Chevy BB. All parts are in excellent condition with less that 10 hrs of run time. All prices plus shipping from 34786.
Can send MORE Pictures by request if necessary
1. GM BB 8" Balancer Externally Balanced #10216339 (was only used to start engine; run less than 10 hrs) - $85 (NEW from GM $179)
2. LUK EXTERNALLY BALANCED 454 Flywheel for Chevy BIG BLOCK (note surface burnt areas, shouldn't interfere with operation) - $70
3. USED MELLING #77HV High Volume oil pump with screen for a Chevy 396-454. The GM screen was JB WELDED to the body of the pump.
$35.00
4. USED Edelbrock Performer RPM Air Gap Intake Manifold-#7561 Oval CHEVY Big Block w/NEW SEALED Fel-Pro Performance Intake Manifold Gasket Set #1210 - $210 SOLD
5. CORVETTE 63-82 New REAR SPRING MOUNT CUSHIONS (4) and REAR SPRING MOUNT CUPS(4) Reproductions - $10
6. PROBE FORGED DOME PISTONS & RODS #P4963F-060 For 496 (pistons can be removed from rods and used in any .060 engine - $525.00 SOLD
7. PROCOMP #3021 assembled aluminum big block Chevy cylinder heads/118cc & 300cc intake runners. Included are Guide plates, screw in studs, 12-Point Cylinder Head Bolt Kits (NO WASHERS) for Aluminum Heads. They were used less than 10 hours - $800.00 SOLD
8. GM SHORT STYLE DATED WATER PUMP #3856284 D 27 7 on separate listing $150.00
9. BRAND NEW GM LONG-STYLE Water Pump (take-off) for Chevy BBC 396/427/454/502 - #12554747. (same as GM pump #12484890). $85.00
10. GM Muncie 4 speed shifter with arms and rods (removed from a 65 Corvette) $160
11. Brand New GM Automatic Flexplate for Big Block ( never used) $45
ALL PRICES PLUS SHIPPING FROM 34786
PRICES ARE LOW ALREADY BUT MAKE ME A REASONABLE OFFER ON ANY PART ABOVE
$35.00
Last edited by nfran; 08-03-2014 at 01:27 PM. Reason: Additions,Updates, lowered prices
ProComp Alum Cylinder Heads
These parts were on a 496 Chevy BB. All parts are in excellent condition with less that 10 hrs of run time. All prices plus shipping from 34786. Can send Pictures by request if necessary
1. GM BB 8" Balancer Externally Balanced #10216339 - $125
2. LUK EXTERNALLY BALANCED 454 Flywheel for Chevy BIG BLOCK (note surface burnt areas, shouldn't interfere with operation) - $95
3. MELLING High Volume oil pump & screen (JB Welded screen to pump) for a Chevy 396-454 - $35
5. Used Tru-Flow (NAPA) Mechanical Water Pump (long) for Chevy BBC 396/427/454 #44088 - $60 SOLD
6. CORVETTE 63-82 New REAR SPRING MOUNT CUSHIONS (4) and REAR SPRING MOUNT CUPS(4) Reproductions - $12
7. PROBE FORGED DOME PISTONS & RODS #P4963F-060 For 496 (pistons can be removed from rods and used in any .060 engine - $600
8. PROCOMP #3021 assembled aluminum big block Chevy cylinder heads/118cc & 300cc intake runners. Included are Guide plates, screw in studs, 12-Point Cylinder Head Bolt Kits (NO WASHERS) for Aluminum Heads. They were used less than 10 hours - $800.00
Updates and additions to list
