Started the nut and bolt restoration of 64 coupe that needs a back half frame replacement. From about 12" forward of the kick up to above the kick is very bad. Further back the pitting is bad enough to require replacement also.
Have a mid 64 coupe solid frame all repairs have been done ready to go. Complete roller still has factory drum set up and the rear assembly has been rebuilt 3:70 ratio BB axle shafts. Was going to re use it but decided to go with a resto rod chassis. Located in central fl. $6500.00 if you or any one else is interested send me your email will send pics .
